Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TL750M12CKC — Даташит
СерияTL750M12
МодельTL750M12CKC
LDO с одним выходом, 750 мА, фиксированный (12,0 В), низкий ток покоя, защита от сброса нагрузки 60 В 3-TO-220 от 0 до 125
Pin3
Package TypeKC
Industry STD TermTO-220
JEDEC CodeR-PSFM-T
МаркировкаTL750M12C
Width (мм)9.02
Length (мм)10.17
Thickness (мм)4.58
Pitch (мм)2.54
Max Height (мм)4.7
Accuracy(%)1
Additional FeaturesOvercurrent Protection
Thermal Shutdown
Approx. Price (US$)0.42 | 1ku
Fixed Output Options(V)12
Iout(Max)(A)0.75
Iq(Typ)(mA)5
Noise(uVrms)1000
Operating Temperature Range(C)0 to 125
Output OptionsFixed Output
Package GroupTO-220
Package Size: mm2:W x L (PKG)See datasheet (TO-220)
Powered LoadFPGA
Microcontroller
Microprocessor
Regulated Outputs(#)1
Vdo(Typ)(mV)600
Vin(Max)(V)26
Vin(Min)(V)13
Vout(Max)(V)12
Vout(Min)(V)12
RoHSНе совместим
  • Using Thermal Calculation Tools for Analog Components
    PDF, 1.1 Мб, Файл опубликован: 2 сен 2010
    This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
Серия: TL750M12 (3)
На английском языке: Datasheet Texas Instruments TL750M12CKC
