Datasheet Texas Instruments SN74LVC245ANSRG4 — Даташит
| Серия | SN74LVC245A |
| Модель | SN74LVC245ANSRG4 |
Восьмеричный шинный трансивер с выходами с 3 состояниями 20-SO от -40 до 125
SN74LVC245A Octal Bus Transceiver With 3-State Outputs datasheet
PDF, 1.6 Мб, Версия: X, Файл опубликован: 25 янв 2015
Купить SN74LVC245ANSRG4 на РадиоЛоцман.Цены — от 4.29 до 26 ₽9 предложений от 9 поставщиков Микросхема Логический контроллер, Octal Bus Transceiver With 3-State Outputs 20-SO -40℃ to 125℃ | |||
| SN74LVC245ANSRG4 Texas Instruments | 4.29 ₽ | ||
| SN74LVC245ANSRG4 Texas Instruments | 10 ₽ | ||
| SN74LVC245ANSRG4 Texas Instruments | 26 ₽ | ||
| SN74LVC245ANSRG4 | по запросу | ||
| Pin | 20 |
| Package Type | NS |
| Industry STD Term | SOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | LVC245A |
| Width (мм) | 5.3 |
| Length (мм) | 12.6 |
| Thickness (мм) | 1.95 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2 |
| Mechanical Data | Скачать |
| Bits | 8 |
| F @ Nom Voltage(Max) | 100 Mhz |
| ICC @ Nom Voltage(Max) | 0.03 мА |
| Output Drive (IOL/IOH)(Max) | -24/24 мА |
| Package Group | SO |
| Package Size: mm2:W x L | 20SO: 98 mm2: 7.8 x 12.6(SO) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | LVC |
| VCC(Max) | 3.6 В |
| VCC(Min) | 1.65 В |
| Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
| tpd @ Nom Voltage(Max) | 12.7,8.3,7.3,6.3 нс |
Серия: SN74LVC245A (29)
- SN74LVC245ADBLE SN74LVC245ADBR SN74LVC245ADBRE4 SN74LVC245ADBRG4 SN74LVC245ADGVR SN74LVC245ADW SN74LVC245ADWG4 SN74LVC245ADWR SN74LVC245ADWRE4 SN74LVC245ADWRG4 SN74LVC245AGQNR SN74LVC245AN SN74LVC245ANE4 SN74LVC245ANSR SN74LVC245ANSRG4 SN74LVC245APW SN74LVC245APWE4 SN74LVC245APWG4 SN74LVC245APWLE SN74LVC245APWR SN74LVC245APWRE4 SN74LVC245APWRG3 SN74LVC245APWRG4 SN74LVC245APWT SN74LVC245APWTE4 SN74LVC245APWTG4 SN74LVC245ARGYR SN74LVC245ARGYRG4 SN74LVC245AZQNR
- Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
