Оптопары и оптореле Megawin
Datasheet Texas Instruments DS26LS31CM/NOPB — Даташит
СерияDS26LS31C
МодельDS26LS31CM/NOPB
Четырехскоростные драйверы дифференциальной линии 16-SOIC от 0 до 70
DS26LS31C/DS26LS31M Quad High Speed Differential Line Driver datasheet
PDF, 894 Кб, Версия: C, Файл опубликован: 15 апр 2013
Pin16
Package TypeD
Package QTY48
МаркировкаDS26LS31CM
Width (мм)3.91
Length (мм)9.9
Thickness (мм)1.58
Max Height (мм)1.75
ICC(Max)60 мА
Signaling Rate10 Mbps
Supply Voltage(s)5 В
  • AN-805 Calculating Power Dissipation for Differential Line Drivers (Rev. B)
    PDF, 200 Кб, Версия: B, Файл опубликован: 30 апр 2013
    The purpose of this application report is to provide end users with a sample power dissipation calculation for typical TIA/EIA-422 and TIA/EIA-485 differential line drivers. Other topics that are addressed include worst case power dissipation and packaging/thermal considerations.
  • AN-903 A Comparison of Differential Termination Techniques (Rev. B)
    PDF, 279 Кб, Версия: B, Файл опубликован: 26 апр 2013
    The purpose of this application report is to remove some of the confusion that may surround signal termination. This discussion will focus attention upon signal termination only as it applies to differential data transmission over twisted pair cable. Common differential signal termination techniques will be presented and the advantages and disadvantages of each will be discussed.
На английском языке: Datasheet Texas Instruments DS26LS31CM/NOPB
