Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet ТI LM2577T-ADJ — Даташит
СерияLM2577
МодельLM2577T-ADJ
Datasheet Texas Instruments LM2577T-ADJ
SIMPLE SWITCHER® 3,5–40 В, 3 А, малокомпонентный повышающий стабилизатор 5-TO-220 от -40 до 125
LM1577/LM2577 SIMPLE SWITCHER Step-Up Voltage Regulator datasheet
PDF, 4.0 Мб, Версия: D, Файл опубликован: 3 апр 2013
  • AN-777 LM2577 Three Output, Isolated Flyback Regulator (Rev. B)
    PDF, 278 Кб, Версия: B, Файл опубликован: 23 апр 2013
    Many voltage regulator applications require multiple outputs, such as a computer's power supply or aregulator used to meet the voltage requirements inside an automobile. Some of these applications requireisolation between the regulator's input and output for protection and separate ground specifications. Usingthese criteria, a LM2577 simple switcher flyback regulator has been designed with m
  • AN-776 20-W SIMPLE SWITCHER Forward Converter (Rev. A)
    PDF, 593 Кб, Версия: A, Файл опубликован: 23 апр 2013
    This application note provides information about the 20-watt simple switcher forward converter.
  • Working With Boost Converters
    PDF, 159 Кб, Файл опубликован: 15 июн 2015
    This brief note highlights some of the more common pitfalls when using boost regulators. These includemaximum achievable output current and voltage, short circuit behavior and basic layout issues. It isassumed that the reader is familiar with the basic operation of a boost regulator.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • Negative Buck Switching Regulator (using LM258x)
    PDF, 122 Кб, Файл опубликован: 21 мар 2007
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Switching Regulator Fundamentals (Rev. A)
    PDF, 324 Кб, Версия: A, Файл опубликован: 23 сен 2016
    Theswitchingregulatoris increasingin popularitybecauseit offersthe advantagesof higherpowerconversionefficiencyand increaseddesignflexibility(multipleoutputvoltagesof differentpolaritiescan begeneratedfroma singleinputvoltage).
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
LM2577TADJ, LM2577T ADJ
На английском языке: Datasheet Texas Instruments LM2577T-ADJ
Политика конфиденциальности
