Datasheet Texas Instruments TRS232DW — Даташит
| Серия | TRS232 |
| Модель | TRS232DW |
Двойной драйвер/приемник RS-232 с защитой IEC61000-4-2, 16-SOIC, от 0 до 70
Dual RS-232 Driver/Receiver With IEC61000-4-2 Protection datasheet
PDF, 926 Кб, Версия: A, Файл опубликован: 23 сен 2008
Купить TRS232DW на РадиоЛоцман.Цены — от 44 до 154 ₽16 предложений от 14 поставщиков IC TRANSCEIVER FULL 2/2 16SOIC. 2/2 Transceiver Full RS232 16-SOIC. Interface - Drivers, Receivers, Transceivers | |||
| TRS232DW Texas Instruments | от 154 ₽ | ||
| TRS232DW Texas Instruments | по запросу | ||
| TRS232DW Rochester Electronics | по запросу | ||
| Pin | 16 |
| Package Type | DW |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 40 |
| Carrier | TUBE |
| Маркировка | TRS232 |
| Width (мм) | 7.5 |
| Length (мм) | 10.3 |
| Thickness (мм) | 2.35 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 2.65 |
| Mechanical Data | Скачать |
| Data Rate(Max) | 120 kbps |
| Drivers Per Package | 2 |
| ESD HBM | 2 kV |
| Logic Voltage(Min) | 5 В |
| Main Supply Voltage(Nom) | 5 В |
| Рабочий диапазон температур | от -40 до 85,0 до 70 C |
| Package Group | SOIC |
| Rating | Catalog |
| Receivers Per Package | 2 |
- Wave Solder Exposure of SMT PackagesPDF, 206 Кб, Файл опубликован: 9 сен 2008
It is common practice to attach surface mount components to the underside of a printed circuit board (PCB) by processing the PCB through a wave soldering operation after gluing the components to the PCB. This paper ummarizes results of several tests performed to understand the performance of surface mount components when exposed to the conditions outlined in JESD22A111.
- Semiconductors > Interface > RS-232
