Datasheet Texas Instruments UA741MJG — Даташит
СерияUA741
МодельUA741MJG
Операционный усилитель общего назначения 8-CDIP от -55 до 125
µA741 General-Purpose Operational Amplifiers datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 2 май 2017
Package TypeJG
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Width (мм)6.67
Length (мм)9.6
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Рекомендуемая замена
ReplacementTLE2021MJG
Replacement CodeQ
Additional FeaturesVos Adj Pin
Approx. Price (US$)0.11 | 1ku
АрхитектураBipolar
CMRR(Min)(dB)70
CMRR(Typ)(dB)90
GBW(Typ)(MHz)1
Input Bias Current(Max)(pA)500000
Iq per channel(Max)(mA)2.8
Iq per channel(Typ)(mA)1.7
Number of Channels(#)1
Output Current(Typ)(mA)25
Package GroupPDIP
SO
SOIC
See datasheet (CDIP)
Rail-to-RailNo
Slew Rate(Typ)(V/us)0.5
Total Supply Voltage(Max)(+5V=5, +/-5V=10)36
Total Supply Voltage(Min)(+5V=5, +/-5V=10)7
Vn at 1kHz(Typ)(nV/rtHz)20
Vos (Offset Voltage @ 25C)(Max)(mV)5
RoHSНе совместим
  • Understanding Operational Amplifier Specifications
    PDF, 273 Кб, Файл опубликован: 13 июл 1998
    Selecting the right operational amplifier for a specific application requires you to have your design goals clearly in mind along with a firm understanding of what the published specifications mean. This paper addresses the issue of understanding data sheet specifications.This paper begins with background information. First introductory topics on the basic principles of amplifiers are presen
  • Handbook of Operational Amplifier Applications (Rev. B)
    PDF, 2.8 Мб, Версия: B, Файл опубликован: 19 сен 2016
    While in the process of reviewing Texas Instruments applications notes including those from Burr-Brown - I uncovered a couple of treasures this handbook on op amp applications and one on active RC networks. These old publications from 1963 and 1966 respectively are some of the finest works on op amp theory that I have ever seen. Nevertheless they contain some material that is hopelessly outd
На английском языке: Datasheet Texas Instruments UA741MJG
