Datasheet ТI TPS54973PWPRG4 — Даташит
| Серия | TPS54973 |
| Модель | TPS54973PWPRG4 |
Синхронный понижающий преобразователь на входе 3,3 В, ток 9 А для выходов с предсмещением 28-HTSSOP от -40 до 85
3-V to 4-V Input 9-A Output Synchronous Buck Switcher datasheet
PDF, 700 Кб, Версия: A, Файл опубликован: 8 мар 2005
- Sequencing with TPS54x80 and TPS54x73 DC/DC ConvertersPDF, 169 Кб, Файл опубликован: 14 апр 2003
Design of a power supply for a high-performance point-of-load processor requires special attention to manage core and input/output (I/O) voltage sequencing, which is critical to device operation and long term reliability. The TPS54x80 devices of low input voltage synchronous-buck dc/dc converters are designed for easily implementing sequential, ratio-metric, or simultaneous sequencing schemes. F - Thermal Performance of SWIFT(TM) DC/DC Converters in the 28-Pin HTSSOP PackagePDF, 267 Кб, Файл опубликован: 4 фев 2005
The thermal management of printed-circuit boards is complex, but must be well understood to achieve optimum performance and reliability. SWIFT(TM) dc/dc converters in the 28-pin HTSSOP package rely on an exposed lead frame die pad [PowerPAD(TM)] on the bottom of the package to provide an extremely low thermal resistance from junction to case. The thermal performance of the 6-, 9-, and 14-A SWIFT d - Using Low Voltage SWIFT DC/DC Converters with Ceramic CapacitorsPDF, 490 Кб, Файл опубликован: 8 янв 2003
This application note investigates an adequate phase margin for stable operation of SWIFTв„ў regulators with the ceramic capacitors at worst-case tolerances of regulator and external parts. TI also shows how the bandwidth and gain of feedback loop impact on load-current transient-response characteristics. Measurements and analysis have shown that the voltage-mode control SWIFTв„ў regulat
Серия: TPS54973 (3)
- TPS54973PWP TPS54973PWPR TPS54973PWPRG4
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
