Datasheet Texas Instruments TL494CNSRG4 — Даташит
СерияTL494
МодельTL494CNSRG4
Цепь управления ШИМ 16-SO от 0 до 70
TL494 Pulse-Width-Modulation Control Circuits datasheet
PDF, 1.3 Мб, Версия: H, Файл опубликован: 27 фев 2017
Pin16
Package TypeNS
Industry STD TermSOP
Package QTY2000
МаркировкаTL494
Width (мм)5.3
Length (мм)10.3
Thickness (мм)1.95
Max Height (мм)2
Control MethodVoltage
Duty Cycle(Max)45 %
Frequency(Max)300 kHz
Frequency(Min)1 kHz
Gate Drive(Typ)0.2 A
Package GroupSO
Special FeaturesAdjustable Switching Frequency,Error Amplifier,Multi-topology
TopologyBoost,Buck,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull
UVLO Thresholds On/OffN/A В
Vin(Max)38 В
Vin(Min)-0.3 В
  • Isolated Multiple Output Flyback Converter Design Using TL494
    PDF, 741 Кб, Файл опубликован: 18 июн 2014
  • Off-Line SMPS Failure Modes PWM Switchers and DC-DC Converters
    PDF, 71 Кб, Файл опубликован: 22 мар 2000
    Today's voltage regulator modules (VRMs) employ off-line SMPS techniques. Traditionally, they are usually discarded when they fail because they are so challenging to debug and so inexpensive to replace. Investigation of these failed modules reveals some common failure modes. Some failures are caused by other systems' passive components that fail after repeated electrical stress. Recognizing these
  • Designing Switching Voltage Regulators With the TL494 (Rev. E)
    PDF, 329 Кб, Версия: E, Файл опубликован: 26 июл 2005
  • Understanding Buck Power Stages In Switchmode Power Supplies
    PDF, 173 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
На английском языке: Datasheet Texas Instruments TL494CNSRG4
