Datasheet Texas Instruments SN74AUC16244ZQLR — Даташит
Серия | SN74AUC16244 |
Модель | SN74AUC16244ZQLR |
16-битный буфер/драйвер с выходами с 3 состояниями 56 BGA MICROSTAR JUNIOR от -40 до 85
16-Bit Buffer/Driver With 3-State Outputs datasheet
PDF, 830 Кб, Версия: E, Файл опубликован: 28 фев 2008
Pin | 56 |
Package Type | ZQL |
Industry STD Term | BGA MICROSTAR JUNIOR |
JEDEC Code | R-PBGA-N |
Package QTY | 1000 |
Carrier | LARGE T&R |
Маркировка | MH244 |
Width (мм) | 4.5 |
Length (мм) | 7 |
Thickness (мм) | .75 |
Pitch (мм) | .65 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Bits | 16 |
F @ Nom Voltage(Max) | 250 Mhz |
ICC @ Nom Voltage(Max) | 0.02 мА |
Output Drive (IOL/IOH)(Max) | -9/9 мА |
Package Group | BGA MICROSTAR JUNIOR |
Package Size: mm2:W x L | 56BGA MICROSTAR JUNIOR: 32 mm2: 4.5 x 7(BGA MICROSTAR JUNIOR) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | AUC |
VCC(Max) | 2.7 В |
VCC(Min) | 0.8 В |
Voltage(Nom) | 0.8,1.2,1.5,1.8,2.5 В |
tpd @ Nom Voltage(Max) | 5.4,2.8,1.9,1.8 нс |
- Simultaneous-Switching Performance of TI Logic Devices (Rev. B)PDF, 378 Кб, Версия: B, Файл опубликован: 23 фев 2005
Simultaneous-switching noise can generate and propagate glitches in electronic systems. Therefore, system designers are faced with challenges to minimize simultaneous-switching noise, while increasing switching speed and improving signal quality. This report presents the performance of different TI logic devices under various simultaneous-switching conditions. Factors such as the number of bits sw - Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus DevicesPDF, 374 Кб, Файл опубликован: 21 мар 2003
System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
Серия: SN74AUC16244 (4)
- SN74AUC16244DGGR SN74AUC16244DGVR SN74AUC16244GQLR SN74AUC16244ZQLR
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
