Datasheet Texas Instruments THS6022IPWPR — Даташит
СерияTHS6022
МодельTHS6022IPWPR
Двойной дифференциальный линейный драйвер 250 мА 14-HTSSOP
250-mA Dual Differential Line Driver datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 27 июл 2007
Pin14
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаHS6022I
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
2nd Harmonic76 dBc
3rd Harmonic80 dBc
@ MHz1
Acl, min spec gain1 V/V
Additional FeaturesN/A
АрхитектураCurrent FB
BW @ Acl210 МГц
CMRR(Min)62 дБ
CMRR(Typ)73 дБ
GBW(Typ)210 МГц
Input Bias Current(Max)10000000 pA
Iq per channel(Max)9 мА
Iq per channel(Typ)7.2 мА
Количество каналов2
Offset Drift(Typ)20 uV/C
Рабочий диапазон температурот 0 до 70,-40 до 85 C
Output Current(Typ)250 мА
Package GroupHTSSOP
Package Size: mm2:W x L14HTSSOP: 32 mm2: 6.4 x 5(HTSSOP) PKG
Rail-to-RailNo
Slew Rate(Typ)1900 V/us
Total Supply Voltage(Max)33 +5V=5, +/-5V=10
Total Supply Voltage(Min)9 +5V=5, +/-5V=10
Vn at 1kHz(Typ)1.8 нВ/rtГц
Vn at Flatband(Typ)1.7 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)5 мВ
  • Evaluation Modules & Boards: THS6022EVM
    THS6022 High Speed Amplifier Evaluation Modules
  • Active Output Impedance for ADSL Line Drivers
    PDF, 636 Кб, Файл опубликован: 26 ноя 2002
    Signal termination is very common in bidirectional communication systems. Termination allows for receiving signals while transmitting different signals at the same time. With the increasing popularity of asymmetrical digital subscriber lines (ADSL), the requirement for a low power line driver amplifier combined with line termination becomes a very difficult goal. This application note examines the
На английском языке: Datasheet Texas Instruments THS6022IPWPR
