Линейка продуктов KEEN SIDE
Datasheet Texas Instruments DAC7654YT — Даташит
СерияDAC7654
МодельDAC7654YT
16-битный цифро-аналоговый преобразователь с четырьмя выходами по напряжению 64-LQFP от -40 до 85
DAC7654: 16-Bit, Quad Voltage Output Digital-To-Analog Converter datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 13 дек 2005
Pin64
Package TypePM
Industry STD TermLQFP
JEDEC CodeS-PQFP-G
Package QTY250
CarrierSMALL T&R
МаркировкаDAC7654Y
Width (мм)10
Length (мм)10
Thickness (мм)1.4
Pitch (мм).5
Max Height (мм)1.6
Code to Code Glitch(Typ)1 nV-sec
DAC ArchitectureR-2R
DAC Channels4
Gain Error(Max)0.8 %FSR
INL(Max)3 +/-LSB
InterfaceSPI
Offset Error(Max)N/A %
Output Range Max.2.5 mA/V
Output Range Min.-2.5 mA/V
Тип выходаBuffered Voltage
Package GroupLQFP
Package Size: mm2:W x L64LQFP: 144 mm2: 12 x 12(LQFP) PKG
Power Consumption(Typ)18 mW
Reference: TypeExt,Int
Разрешение16 Bits
Sample / Update Rate0.1 MSPS
Время установления12 µs
Special FeaturesReset to Mid-Scale,SDO
Zero Code Error(Typ)5 мВ
  • Evaluation Modules & Boards: DAC7654EVM
    DAC7654 Evaluation Module
  • Interfacing the DAC7654 to the MSP430F449
    PDF, 411 Кб, Файл опубликован: 16 авг 2004
    This application report shows how easy it is to interface the DAC7654 digital-to-analog converter to the MSP430F449 mixed signal microcontroller using the SPI mode of serial communication. By using the software program provided in this application report, a simple routine can be created to generate a sinusoidal waveform. Using the DAC7654 EVM along with the HPA449 evaluation system makes developin
  • Interfacing the TLC4541 & the DAC7654 to the MSP430F449
    PDF, 877 Кб, Файл опубликован: 12 авг 2005
    The purpose of this application report is to demonstrate the combination of a serial analog-to-digital converter (ADC) and a serial digital-to-analog converter (DAC) on a development platform. The ADC and the DAC featured are the TLC4541 and the DAC7654, respectively. These devices are presented using the HPA449 as a low-cost development platform. The application report briefly describes each comp
Серия: DAC7654 (3)
На английском языке: Datasheet Texas Instruments DAC7654YT
