Datasheet Texas Instruments LM2574HVMX-15/NOPB — Даташит
СерияLM2574HV
МодельLM2574HVMX-15/NOPB
ПРОСТОЙ ПЕРЕКЛЮЧАТЕЛЬ 0,5 А Понижающий стабилизатор напряжения 14-SOIC от -40 до 125
LM2574x SIMPLE SWITCHERВ® 0.5-A Step-Down Voltage Regulator datasheet
PDF, 3.2 Мб, Версия: D, Файл опубликован: 27 апр 2016
36 предложений от 17 поставщиков
LM2574HVMX-15/NOPB
322 ₽
LM2574HVMX-15/NOPB
370 ₽
SUV System
LM2574HVMX-15/NOPB
LM2574HVMX-15/NOPB
Pin1414
Package TypeNPANPA
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY10001000
CarrierLARGE T&RLARGE T&R
Маркировка-15 P+LM2574HVM
Width (мм)7.4987.498
Length (мм)8.9928.992
Thickness (мм)2.3012.301
Pitch (мм)1.271.27
Max Height (мм)2.652.65
Control ModeVoltage Mode
Duty Cycle(Max)98 %
Iout(Max)0.5 A
Iq(Typ)5 мА
Regulated Outputs1
Special FeaturesEnable
Switching Frequency(Max)52 kHz
Switching Frequency(Min)52 kHz
ТипConverter
Vin(Max)60 В
Vin(Min)4 В
Vout(Max)37 В
Vout(Min)3.3 В
  • Cost-Effective Transformerless Offline Supply for Light Load Applications (Rev. A)
    PDF, 295 Кб, Версия: A, Файл опубликован: 16 июн 2015
    This design idea provides a simple non-isolated AC/DC power supply for low power applications. Thedesign uses a "capacitive-dropper" front-end combined with a LM46000 SIMPLE SWITCHERВ® buckregulator from Texas Instruments. The circuit provides 3.3 V at a minimum of 100 mA from a line supply of90 VAC to 265 VAC. Theory of operation as well as design equations and performance results are given.
  • Cap Drop Offline Supply for E-Meters
    PDF, 291 Кб, Файл опубликован: 16 июн 2015
    This design idea provides a simple non-isolated AC/DC power supply for low power applications such assmart grid E-meter applications. The design uses a "capacitive-dropper" front-end combined with aLM46000 SIMPLE SWITCHERВ® buck regulator from Texas Instruments. The circuit provides 3.3 V at aminimum of 50 mA from a line supply of 90 VAC to 265 VAC. Theory of operation as well as designequa
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
LM2574HVMX15/NOPB, LM2574HVMX 15/NOPB
На английском языке: Datasheet Texas Instruments LM2574HVMX-15/NOPB
