Datasheet Texas Instruments LM3402HVMR/NOPB — Даташит
СерияLM3402HV
МодельLM3402HVMR/NOPB
Понижающий стабилизатор постоянного тока 0,5 А для драйверов светодиодов высокой мощности 8-SO PowerPAD
LM3402/HV 0.5-A Constant Current Buck Regulator for Driving High Power LEDs datasheet
PDF, 1.5 Мб, Версия: F, Файл опубликован: 29 окт 2015
25 предложений от 15 поставщиков
IC LED DRVR RGLTR DIM 500MA 8SO. LED Driver IC 1 Output DC DC Regulator Step-Down (Buck) PWM Dimming 500mA 8-SO...
LM3402HVMR/NOPB
72 ₽
Рутоника
LM3402HVMR/NOPB
77 ₽
LM3402HVMR/NOPB
187 ₽
LM3402HVMR/NOPB
Pin88
Package TypeDDADDA
Industry STD TermHSOICHSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY9595
CarrierTUBETUBE
МаркировкаHVMRL3402
Width (мм)3.93.9
Length (мм)4.894.89
Thickness (мм)1.481.48
Pitch (мм)1.271.27
Max Height (мм)1.71.7
Dimming MethodPWM
Входное напряжениеDC/DC Type
Iout(Max)0.5 A
Iq(Typ)0.6 мА
Package GroupSO PowerPAD
Package Size: mm2:W x L8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) PKG
Power Factor CorrectionN/A Min
Regulated Outputs1
Special FeaturesAdjustable Switch Frequency,Enable/Shutdown,Integrated Switch,Thermal Shutdown
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)20 kHz
TopologyBuck
ТипInductive
Vin(Max)75 В
Vin(Min)6 В
Vout(Max)73 В
Vout(Min)0.2 В
Vref0.2 В
  • Evaluation Modules & Boards: LM3404MREVAL
    LM3402 LM3404 High Power PSOP-8 Evaluation board
  • Evaluation Modules & Boards: LM3402HVEVAL
    LM3402HVMA (Mini SOIC) - 0.5A Constant Current Buck HV Regulator for HB LEDs (LM3402HVEVAL Board)
  • Evaluation Modules & Boards: LM3404FSTDIMEV
    LM3404FSTDIMEV - Fast Dimming and True Constant LED Current Evaluation Board
  • AN-1982 Small, Wide Input Voltage Range LM2842 Keeps LEDs Cool (Rev. A)
    PDF, 60 Кб, Версия: A, Файл опубликован: 23 апр 2013
    The world seems to be poised to make the leap to LED lighting. Incandescent has been deemed tooinefficient, which it is, and fluorescent lighting often does not achieve the lifetime it claims. Fluorescentalso has another set of baggage, dangerous chemicals. So the logical choice that most people believe cantake the crown is high brightness (HB) LEDs. HBLEDs are becoming more attractive as th
  • Driving LEDs: To Cap or Not to Cap
    PDF, 542 Кб, Файл опубликован: 21 мар 2007
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3402HVMR/NOPB
