Datasheet Texas Instruments ADS1213EG4 — Даташит
СерияADS1213
МодельADS1213EG4
22-битный аналого-цифровой преобразователь 28-SSOP от -40 до 85
ADS1212, ADS1213: 22-Bit Analog-to-Digital Converter datasheet
PDF, 1.5 Мб, Версия: B, Файл опубликован: 18 фев 2004
Pin28
Package TypeDB
Industry STD TermSSOP
Package QTY50
МаркировкаADS1213E
Width (мм)5.3
Length (мм)10.2
Thickness (мм)1.95
Max Height (мм)2
  • Calibration Routines and Register Value Generation for the ADS121x Series
    PDF, 298 Кб, Файл опубликован: 19 июн 2003
    In order to achieve the best possible performance, offset and gain can be often be calibrated in high-resolution analog-to-digital converters (ADCs). Changes in temperature, PGA gain, power supply voltage, or most importantly, decimation ratio can influence the accuracy of measurement. This application note explains how the calibration routines work and how to generate values for the full-scale re
  • Programming Tricks for Higher Conversion Speeds Utilizing Delta Sigma Converters
    PDF, 105 Кб, Файл опубликован: 27 сен 2000
    Delta-Sigma Analog-to-Digital Converters are well known for their innate ability to resolve an analog input signal to very small LSB voltage ranges. The primarily applications for this type of product is in the Industrial Process Control market such as direct transducer interface for pressure, temperature, flow, weigh scales and force measurement systems.
  • Inputs Currents for High-Resolution ADCs
    PDF, 127 Кб, Файл опубликован: 6 мар 2003
  • Coding Schemes Used with Data Converters (Rev. A)
    PDF, 70 Кб, Версия: A, Файл опубликован: 15 май 2015
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS1213EG4
