Datasheet Texas Instruments ADS1118IRUGT — Даташит
СерияADS1118
МодельADS1118IRUGT
16-разрядный, 860SPS, 4-канальный дельта-сигма АЦП с PGA, генератором, опорным напряжением, датчиком температуры и SPI 10-X2QFN от -40 до 125
ADS1118 Ultrasmall, Low-Power, SPI-Compatible, 16-Bit Analog-to-Digital Converter with Internal Reference and Temperature Sensor datasheet
PDF, 1.5 Мб, Версия: E, Файл опубликован: 24 окт 2014
Pin10
Package TypeRUG
Industry STD TermX2QFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаSDQ
Width (мм)2
Length (мм)1.5
Thickness (мм).37
Pitch (мм).5
Max Height (мм).4
# Input Channels4
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)2 В
АрхитектураDelta-Sigma
Digital Supply(Max)5.5 В
Digital Supply(Min)2 В
INL(Max)1 +/-LSB
Input Range(Max)5.5 В
Тип входаDifferential,Single-Ended
Integrated FeaturesOscillator,PGA,Temp Sensor
InterfaceSPI
Package GroupX2QFN
Package Size: mm2:W x L10X2QFN: 3 mm2: 2 x 1.5(X2QFN) PKG
Power Consumption(Typ)0.3 mW
Reference ModeInt
Разрешение16 Bits
Sample Rate (max)860SPS SPS
Sample Rate(Max)0.00086 MSPS
  • Evaluation Modules & Boards: 430BOOST-ADS1118
    ADS1118 BoosterPack
  • Evaluation Modules & Boards: ADS1118EVM
    ADS1118 Evaluation Module
  • Precision Thermocouple Measurement with the ADS1118
    PDF, 587 Кб, Файл опубликован: 21 авг 2011
    Thermocouples are a very common form of temperature measurement devices that are widely used in both industrial and general-purpose applications. Traditionally, achieving high system accuracy from thermocouple measurements can be difficult because there are many sources of error within a given system. The ADS1118 is an analog-to-digital converter (ADC) from TI that offers a precision analog front-
  • Digital Filter Types in Delta-Sigma ADCs
    PDF, 219 Кб, Файл опубликован: 27 июн 2017
    This application report discusses digital filters which are a ubiquitous feature in delta-sigma analog todigital converters (ADCs). Digital low-pass filters are essential to the functionality of a delta-sigma ADCwhich relies on oversampling and noise shaping to push quantization noise out of band. There arevariations between the types of digital filters used in delta-sigma ADCs that provide
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
Серия: ADS1118 (4)
На английском языке: Datasheet Texas Instruments ADS1118IRUGT
