Оптопары и оптореле Megawin
Datasheet Texas Instruments UCC28510DW — Даташит
СерияUCC28510
МодельUCC28510DW
Усовершенствованные комбинированные контроллеры PFC/PWM 20-SOIC от -40 до 105
Advanced PFC/PWM Combination Controllers datasheet
PDF, 1.5 Мб, Версия: C, Файл опубликован: 14 сен 2005
Pin20
Package TypeDW
Package QTY25
МаркировкаUCC28510DW
Width (мм)7.5
Length (мм)12.8
Thickness (мм)2.35
Max Height (мм)2.65
Control MethodCCM
Device TypePFC+PWM
Operating Supply Current4 мА
Operating Supply(Max)18 В
Package Size: mm2:W x L20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG
Peak Output Sink Current Gate Drive3 A
Peak Output Source Current Gate Drive-2 A
Practical Operating Frequency(Max)0.5 МГц
Special FeaturesAverage Current Mode,Enable,OVP
Startup Current0.1 мА
UVLO Thresholds On/Off16/10 В
  • Evaluation Modules & Boards: UCC28521EVM
    UCC28521 Evaluation Module
  • Evaluation Modules & Boards: UCC28514EVM
    UCC28514 Evaluation Module
  • UCC28517 100-W PFC power converter with 12-V, 8-W bias supply, Part 2
    PDF, 224 Кб, Файл опубликован: 28 фев 2005
    To conclude the review of the UCC28517 PFC supply, this article covers the design of the second 12-V, 8-W power stage to be used as an auxiliary bias supply.
  • UCC28517 100-W PFC power converter with 12-V, 8-W bias supply, Part 1
    PDF, 202 Кб, Файл опубликован: 28 фев 2005
    Power factor corrected (PFC) preregulators are generally used in ac/dc converters operating above 75 W or to meet line harmonic requirements. This article reviews the design of a 100-W ac/dc power stage with PFC.
  • Bootstrap Circuit for Green Mode Applications
    PDF, 111 Кб, Файл опубликован: 27 янв 2006
  • A New Synchronization Circuit for Power Converters (Rev. A)
    PDF, 209 Кб, Версия: A, Файл опубликован: 21 апр 2010
    The synchronization of multiple PWM and PFC controllers is desirable for many reasons. The most common reason is that it keeps all the noise at one particular frequency and makes it easier to filter. The circuit described changes the slope of the ramp to lock the converter’s switching frequency to an applied signal by a phase locked loop turning it into a voltage controlled oscillator. Furthermore
  • Startup Current transient of the Leading Edge Triggered PFC Controllers
    PDF, 43 Кб, Файл опубликован: 30 июн 2004
  • Avoiding Audible Noise at Light Loads When Using Leading Edge Triggered PFC Con (Rev. C)
    PDF, 57 Кб, Версия: C, Файл опубликован: 13 апр 2011
    This application note applies to the TI average current mode, leading edge modulation PFC controllers. See Applicable Device Table for part numbers.
Серия: UCC28510 (2)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
На английском языке: Datasheet Texas Instruments UCC28510DW
