Datasheet Texas Instruments LM393PSR — Даташит
СерияLM393
МодельLM393PSR
Двойной дифференциальный компаратор 8-SO от 0 до 70
Datasheet LM193, LM293, LM293A, LM393, LM393A, LM2903, LM2903V
PDF, 1.6 Мб, Версия: Y, Файл опубликован: 30 июн 2015, Страниц: 37
Dual Differential Comparators
Package TypePS
Industry STD TermSOP
Package QTY2000
МаркировкаL393
Width (мм)5.3
Length (мм)6.2
Thickness (мм)1.95
Max Height (мм)2
Input Bias Current (+/-)(Max)50 нА
Iq per channel(Max)0.5 мА
Количество каналов2
Тип выходаOpen Collector
Package GroupSO
Package Size: mm2:W x L8SO: 48 mm2: 7.8 x 6.2(SO) PKG
Propagation Delay Time0.3 uS
Rail-to-RailOut
Special FeaturesN/A
VICR(Max)34.5 В
Vos (Offset Voltage @ 25C)(Max)5 мВ
Vs(Max)36 В
Vs(Min)2 В
  • Designing Overcurrent protection for TPL7407L Peripheral Driver
    PDF, 177 Кб, Файл опубликован: 5 ноя 2014
    Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
  • Semiconductors > Amplifiers > Comparators
На английском языке: Datasheet Texas Instruments LM393PSR
