Datasheet ТI OPA684IDBVTG4 — Даташит
СерияOPA684
МодельOPA684IDBVTG4
Datasheet Texas Instruments OPA684IDBVTG4
Маломощный операционный усилитель с токовой обратной связью и отключением 6-SOT-23 от -40 до 85
Low-Power, Current Feedback Operational Amplifier With Disable datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 19 июн 2009
  • Considerations for High-Gain Multistage Designs
    PDF, 347 Кб, Файл опубликован: 13 май 2013
  • Making the Most of a Low-Power, High-Speed Operational Amplifier
    PDF, 221 Кб, Файл опубликован: 22 ноя 2009
    High-speed, high-performance operational amplifiers tend to be associated with high power dissipation. This application note compares the relative performance of several low-power, high-speed operational amplifiers and describes trade-offs to balance performance with low quiescent power dissipation.
  • A Numerical Solution to an Analog Problem
    PDF, 210 Кб, Файл опубликован: 25 апр 2010
    In order to derive a solution for an analog circuit problem, it is often useful to develop a model. This approach is generally accepted as developing an analytical model. However, finding the analytical solution is not always practical or possible as a result of higher-degree polynomials that require further resolution, or because of the time needed to develop the solution completely. In these sit
  • Current Feedback Amplifiers: Review, Stability Analysis, and Applications
    PDF, 53 Кб, Файл опубликован: 20 ноя 2000
    The majority of op amp circuits are closed-loop feedback systems that implement classical control theory analysis. Analog designers are comfortable with Voltage FeedBack (VFB) op amps in a closed-loop system and are familiar with the ideal op amp approximations feedback permit. This application bulletin will demonstrate how CFB op amps can be analyzed in a similar fashion. Once the closed-loop sim
  • Stabilizing Current-Feedback Op Amps While Optimizing Circuit Performance
    PDF, 280 Кб, Файл опубликован: 28 апр 2004
    Optimizing a circuit design with a current-feedback (CFB) op amp is a relatively straightforward task, once one understands how CFB op amps achieve stability. This application note explains a 2nd-order CFB model so that any designer can better understand the flexibility of the CFB op amp. This report also discusses stability analysis, the effects of parasitic components due to PCBs, optimization
  • Expanding the usability of current-feedback amplifiers
    PDF, 215 Кб, Файл опубликован: 28 фев 2005
  • Active filters using current-feedback amplifiers
    PDF, 227 Кб, Файл опубликован: 25 фев 2005
  • RLC Filter Design for ADC Interface Applications (Rev. A)
    PDF, 299 Кб, Версия: A, Файл опубликован: 13 май 2015
    As high performance Analog-to-Digital Converters (ADCs) continue to improve in their performance, the last stage interface from the final amplifier into the converter inputs becomes a critical element in the system design if the full converter dynamic range is desired. This application note describes the performance and design equations for a simple passive 2nd-order filter used successfully in AD
  • ADS5500, OPA695: PC Board Layout for Low Distortion High-Speed ADC Drivers
    PDF, 273 Кб, Файл опубликован: 22 апр 2004
    Once an analog-to-digital converter (ADC) and a driver/interface have been selected for a given application, the next step to achieving excellent performance is laying out the printed circuit board (PCB) that will support the application. This application report describes several techniques for optimizing a high-speed, 14-bit performance, differential driver PCB layout using a wideband operation
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
  • Measuring Board Parasitics in High-Speed Analog Design
    PDF, 134 Кб, Файл опубликован: 7 июл 2003
    Successful circuit designs using high-speed amplifiers can depend upon understanding and identifying parasitic PCB components. Simulating a design while including PCB parasitics can protect against unpleasant production surprises. This application report discusses an easy method for measuring parasitic components in a prototype or final PC board design by using a standard oscilloscope and low freq
На английском языке: Datasheet Texas Instruments OPA684IDBVTG4
Политика конфиденциальности
