Datasheet Texas Instruments UCC29411DG4 — Даташит
СерияUCC29411
МодельUCC29411DG4
Синхронный повышающий преобразователь малой мощности 8-SOIC от -40 до 85
Voltage Regulators - Switching Regulators Low Power Synch Boost Converter
UCC29411DG4
Hi-Tech Circuit Group
UCC29411DG4
Рутоника
UCC29411DG4
UCC29411DG4
Package TypeD
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
RoHSНе совместим
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: UCC29411 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments UCC29411DG4
