Datasheet Texas Instruments TLC5924RHBR — Даташит
СерияTLC5924
МодельTLC5924RHBR
16-канальный светодиодный драйвер с коррекцией точек и полевым транзистором предварительной зарядки 32-VQFN от -40 до 85
16-Channel LED Driver With DOT Correction and Pre-Charge FET datasheet
PDF, 1.2 Мб, Файл опубликован: 20 июн 2006
Pin3232
Package TypeRHBRHB
Industry STD TermVQFNVQFN
JEDEC CodeS-PQFP-NS-PQFP-N
Package QTY30003000
CarrierLARGE T&RLARGE T&R
Маркировка5924TLC
Width (мм)55
Length (мм)55
Thickness (мм).9.9
Pitch (мм).5.5
Max Height (мм)11
Analog Dimming Steps128
Ch to Ch Accuracy(Typ)1 +/- %
Data Transfer Rate(Typ)30 МГц
Package GroupVQFN
Package Size: mm2:W x L32VQFN: 25 mm2: 5 x 5(VQFN) PKG
Special FeaturesError Flag,Fault Detection,LED Open Detection,Power Good
  • LED Driver--Paralleled Outputs Provide High Current Outputs
    PDF, 957 Кб, Файл опубликован: 25 сен 2006
    This application report describes how to use the TLC5922, TLC5923, and TLC5924 to drive high-current LEDs. These ICs are designed to provide 16 individually controllable constant-current sinks. However, the 16 outputs can be connected in parallel to increase the current drive capability. Paralleling the outputs of these ICs allows the TLC5922, TLC5923, and TLC5924 to drive high-power LEDs such as
  • Semiconductors > Power Management > LED Driver > Signage & Large Display LED Driver
На английском языке: Datasheet Texas Instruments TLC5924RHBR
