Datasheet Texas Instruments BQ2003S-NG4 — Даташит
СерияBQ2003
МодельBQ2003S-NG4
Импульсное зарядное устройство NiCd/NiMH аккумуляторов с отрицательной нагрузкой dV и dT/dt, 16-SOIC от -40 до 85
Fast-Charge IC datasheet
PDF, 477 Кб, Версия: A, Файл опубликован: 21 фев 2000
Микросхема Чип управления батареи, Fast Charge Management NiCD/NiMH 2000mA 0V to 5.5V 16Pin SOIC Tube
BQ2003S-NG4
199 ₽
BQ2003S-NG4
403 ₽
BQ2003S-NG4
BQ2003S-NG4
Pin16
Package TypeDW
Package QTY40
Маркировка2003S-N
Width (мм)7.5
Length (мм)10.3
Thickness (мм)2.35
Max Height (мм)2.65
Absolute Vin (safety rating)(Max)(7 В
Battery Charge Voltage(Max)20 В
Cell ChemistryNiCd,NiMH
Charge Current(Max)2 A
Control InterfaceStandalone (RC-Settable)
Control TopologySwitch-Mode Buck
Number of Series Cells1,2,3,4
Operating Vin(Max)5.5 В
Operating Vin(Min)4.5 В
Package Size: mm2:W x L16SOIC: 106 mm2: 10.3 x 10.3(SOIC) PKG
Special FeaturesTemp Monitoring (Thermistor Pin)
USB FeatureN/A
  • Evaluation Modules & Boards: DV2003S1
    BQ2003 Evaluation Module for NiCd/NiMH, switchmode, up to 3A
  • Evaluation Modules & Boards: DV2003S2
    BQ2003 Evaluation Module for NiCd/NiMH, switchmode, up to 6A
  • Evaluation Modules & Boards: DV2003L1
    BQ2003 Evaluation Module for NiCd/NiMH, linear
  • U-506 Step-Down Switching Current - Regulation Using the bq2003 Fast-Charge IC
    PDF, 841 Кб, Файл опубликован: 5 сен 1999
    The bq2003 is a fast-charge IC that provides comprehensive fast-charge control functions and high-speed switching power-control circuitry on a monolithic CMOS device. This application note describes the use of the bq2003 as the modulator in a buck-type switch-mode regulator to fast-charge NiCd and NiMH batteries. Examples include a P-channel MOSFET charger and an N-FET MOSFET charger.
  • U-505 Using the bq2003 to Control Fast Charge
    PDF, 178 Кб, Файл опубликован: 5 сен 1999
    The bq2003 is a fast-charge IC that provides comprehensive fast-charge control functions and high-speed switching power-control circuitry on a monolithic CMOS device. This application note describes the use and functions of the bq2003 gating a current source to fast-charge NiCd or NiMH batteries. Examples illustrate the ease with which the bq2003 is incorporated into applications.
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
BQ2003SNG4, BQ2003S NG4
На английском языке: Datasheet Texas Instruments BQ2003S-NG4
