Datasheet Texas Instruments TPS54318RTER — Даташит
СерияTPS54318
МодельTPS54318RTER
Входное напряжение от 2,95 В до 6 В, ток 3 А, синхронный понижающий преобразователь SWIFT™ 16-WQFN от -40 до 150 В.
TPS54318 2.95-V to 6-V Input, 3-A Output, 2-MHz , Synchronous Step-Down Switcher With Integrated FETs (SWIFTв„ў) datasheet
PDF, 1.6 Мб, Версия: B, Файл опубликован: 26 дек 2014
Pin16
Package TypeRTE
Industry STD TermWQFN
JEDEC CodeS-PQFP-N
Package QTY3000
Маркировка54318
Width (мм)3
Length (мм)3
Thickness (мм).75
Pitch (мм).5
Max Height (мм).8
Control ModeCurrent Mode
Duty Cycle(Max)98 %
Iout(Max)3 A
Iq(Typ)0.35 мА
Рабочий диапазон температурот -40 до 150 C
Package GroupWQFN
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Power Good,Pre-Bias Start-Up,Synchronous Rectification,UVLO Adjustable
Switching Frequency(Max)2000 kHz
Switching Frequency(Min)200 kHz
ТипConverter
Vin(Max)6 В
Vin(Min)2.95 В
Vout(Max)4.5 В
Vout(Min)0.8 В
  • Evaluation Modules & Boards: TPS54318EVM-512
    TPS54318 6V Input, 1.8 Output, 3A SWIFTВ™ Converter Evaluation Module
  • Calculating Efficiency
    PDF, 175 Кб, Файл опубликован: 19 фев 2010
    This application report provides a step-by-step procedure for calculating buck converter efficiency and power dissipation at operating points not provided by the data sheet.
  • Designing Type III Compensation for Current Mode Step-Down Converters (Rev. A)
    PDF, 298 Кб, Версия: A, Файл опубликован: 15 сен 2010
    One of the well-known benefits of current-mode control is that the system stability can be easily achieved by Type II compensation design. It is possible to improve the transient response of a current mode DC/DC converter by adopting Type III compensation to boost the crossover frequency and phase margin. Type III compensation is simple to design and needs only one extra component.
  • Understanding Thermal Dissipation and Design of a Heatsink
    PDF, 59 Кб, Файл опубликован: 4 май 2011
    Power dissipation performance must be well understood prior to integrating devices on a printed-circuit board (PCB) to ensure that any given device is operated within its defined temperature limits. When a device is running, it consumes electrical energy that is transformed into heat. Most of the heat is typically generated by switching devices like MOSFETs, ICs, etc. This application report discu
Серия: TPS54318 (2)
На английском языке: Datasheet Texas Instruments TPS54318RTER
