Линейка продуктов KEEN SIDE
Datasheet Texas Instruments UC3823A-W — Даташит
СерияUC3823A
МодельUC3823A-W
Высокоскоростной ШИМ-контроллер 0-WAFERSALE
UC2823x, UC2825x, UC3823x, UC3825x: High Speed PWM Controller datasheet
PDF, 922 Кб, Версия: E, Файл опубликован: 9 сен 2010
Package TypeYS
Approx. Price (US$)6.73 | 1ku
Control MethodCurrent
Voltage
Duty Cycle(Max)(%)100
Frequency(Max)(kHz)1000
Gate Drive(Typ)(A)2
Package GroupWAFERSALE
Special FeaturesError Amplifier
Leading Edge Blanking
Multi-topology
Soft Start
Synchronization Pin
TopologyBoost
Buck
Flyback
Forward
UVLO Thresholds On/Off(V)9.2/8.4
Vin(Max)(V)22
Vin(Min)(V)8.4
RoHSНе совместим
  • U-128 The UC3823AB and UC3825AB Enhanced Generation of PWM Controllers
    PDF, 204 Кб, Файл опубликован: 5 сен 1999
    The UC3823A and B and the UC3825A and B family of PWM control ICs are improved versions of the standard UC3823 & UC3825 family. This application note describes the enhancements incorporated in four new PWM control ICs: the UC3823A UC3823B UC3825A and UC3825B. Based on the industry standard UC3823 and UC3825 controllers this advanced generation features several key improvements in protection and
  • U-160 Simple Circuit Modifications Enhance Optocoupler Performance
    PDF, 240 Кб, Файл опубликован: 5 сен 1999
    The optocoupler is often used in pulse-width-modulated power converters to transmit an error signal across an isolation boundary. This error signal is used on the primary side to close the control loop. This application note describes a typical optocoupler feedback scheme using the UC3965 Precision Reference with Low-Offset Error Amplifier and a Siemens Optoelectronics IL207 optocoupler. The discu
Серия: UC3823A (5)
  • Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
UC3823AW, UC3823A W
На английском языке: Datasheet Texas Instruments UC3823A-W
