Datasheet Texas Instruments OPA445ADDAG4 — Даташит
СерияOPA445
МодельOPA445ADDAG4
Высоковольтный операционный усилитель с входом на полевых транзисторах 8-SO PowerPAD от -55 до 125
High Voltage FET-Input Operational Amplifier datasheet
PDF, 899 Кб, Версия: B, Файл опубликован: 10 апр 2008
Package TypeDDA
Industry STD TermHSOIC
Package QTY75
МаркировкаOPA445
Width (мм)3.9
Length (мм)4.89
Thickness (мм)1.48
Max Height (мм)1.7
Additional FeaturesN/A
АрхитектураFET
CMRR(Min)80 дБ
CMRR(Typ)95 дБ
GBW(Typ)2 МГц
Input Bias Current(Max)50 pA
Iq per channel(Max)4.7 мА
Iq per channel(Typ)4.2 мА
Количество каналов1
Offset Drift(Typ)10 uV/C
Output Current(Typ)26 мА
Package GroupSO PowerPAD
Package Size: mm2:W x L8SO PowerPAD: 29 mm2: 6 x 4.9(SO PowerPAD) PKG
Rail-to-RailNo
Slew Rate(Typ)15 V/us
Total Supply Voltage(Max)90 +5V=5, +/-5V=10
Total Supply Voltage(Min)20 +5V=5, +/-5V=10
Vos (Offset Voltage @ 25C)(Max)3 мВ
  • Simple Circuit Delivers 38Vp-p at 5A from 28V Unipolar Supply
    PDF, 26 Кб, Файл опубликован: 27 сен 2000
    Since the first analog IC requiring bipolar supplies was developed, people have been trying to operate them from unipolar supplies. Not only do the headroom (VS - VOUTMAX) requirements come into play, but with a unipolar supply typically come unipolar outputs. To get bipolar output swings from a unipolar supply, drive the load differentially and create a reference signal wh
  • Boost Instrument Amp CMR With Common-Mode Driven Supplies
    PDF, 175 Кб, Файл опубликован: 27 сен 2000
    Ever-increasing demands are being placed on instrumentation amplifier (IA) performance. When standard IAs can not deliver the required performance, consider this enhanced version. Dramatic performance improvements can be achieved by operating the input amplifiers of a classical three-op-amp IA from common-mode driven sub-regulated power supplies.
  • Optoelectronics Circuit Collection
    PDF, 261 Кб, Файл опубликован: 11 июн 2001
    This application report presents a collection of analog circuits that may be useful in electro-optic applications such as optical networking. The circuits are Avalanche Photodiode Bias Supply 1; Linear TEC Driver-1, -2, and -3; Laser Diode Driver-1 and -2; and Temperature Under- and Over-range Sensing with a Window Comparator.
  • Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Power Op Amps
На английском языке: Datasheet Texas Instruments OPA445ADDAG4
