Datasheet Texas Instruments TL750M10CKTPRG3 — Даташит
СерияTL750M10
МодельTL750M10CKTPRG3
IC REG LIN 10V 750MA 2POWERFLEX. Linear Voltage Regulator IC 1 Output 750mA 2-PowerFLEXTM. PMIC - Voltage Regulators - Linear...
TL750M10CKTPRG3
65 ₽
Рутоника
TL750M10CKTPRG3
TL750M10CKTPRG3
TL750M10CKTPRG3
Pin2
Package TypeKTP
Industry STD TermPFM
JEDEC CodeR-PSFM-G
Width (мм)6.15
Length (мм)6.04
Thickness (мм)1.91
Pitch (мм)4.57
Max Height (мм)2.03
Accuracy(%)1
Additional FeaturesOvercurrent Protection
Thermal Shutdown
Approx. Price (US$)0.41 | 1ku
Fixed Output Options(V)10
Iout(Max)(A)0.75
Iq(Typ)(mA)5
Noise(uVrms)1000
Operating Temperature Range(C)0 to 125
Output OptionsFixed Output
Package GroupTO-220
TO-252
Package Size: mm2:W x L (PKG)See datasheet (PFM)
See datasheet (TO-220)
Powered LoadFPGA
Microcontroller
Microprocessor
Regulated Outputs(#)1
Vdo(Typ)(mV)600
Vin(Max)(V)26
Vin(Min)(V)11
Vout(Max)(V)10
Vout(Min)(V)10
RoHSНе совместим
На английском языке: Datasheet Texas Instruments TL750M10CKTPRG3
