Datasheet Texas Instruments LM3431MHX/NOPB — Даташит
СерияLM3431
МодельLM3431MHX/NOPB
3-канальный светодиодный драйвер постоянного тока со встроенным повышающим контроллером 28-HTSSOP от -40 до 125
LM3431/31A/31Q/31AQ 3-Chan Constant Current LED Driver w/Integrated Boost Cntr datasheet
PDF, 1.9 Мб, Версия: G, Файл опубликован: 2 май 2013
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY2500
МаркировкаLM3431MH
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Dimming MethodAnalog,PWM
Входное напряжениеDC/DC Type
Iout(Max)0.6 A
Iq(Typ)4 мА
Package GroupHTSSOP
Package Size: mm2:W x L28HTSSOP: 62 mm2: 6.4 x 9.7(HTSSOP) PKG
Power Factor CorrectionN/A Min
Regulated Outputs3
Special FeaturesAdjustable Switch Frequency,Enable/Shutdown,Soft Start,Thermal Shutdown
Switching Frequency(Max)1000 kHz
Switching Frequency(Min)200 kHz
TopologyBoost,Boost with Current Sink,Multi-Channel
ТипController,Inductive
Vin(Max)36 В
Vin(Min)4.5 В
Vout(Max)40 В
Vout(Min)5.5 В
Vref2.5 В
  • Evaluation Modules & Boards: LM3431EVAL
    Evaluation Board for the 3-Channel Constant Current LED Driver with Integrated Boost Controller
  • AN-1656 Design Challenges of Switching LED Drivers (Rev. A)
    PDF, 171 Кб, Версия: A, Файл опубликован: 3 май 2013
    Using a switching regulator as an LED driver requires the designer to convert a voltage regulator into acurrent regulator. Beyond the challenge of changing the feedback system to control current, the LEDsthemselves present a load characteristic that is much different than the digital devices and other loads thatrequire constant voltage. The LED WEBENCHВ® online design environment predicts and
Серия: LM3431 (4)
  • Semiconductors > Power Management > LED Driver > Illumination & General Lighting LED Driver
На английском языке: Datasheet Texas Instruments LM3431MHX/NOPB
