Datasheet Texas Instruments SN65HVD22P — Даташит
СерияSN65HVD22
МодельSN65HVD22P
Расширенный синфазный приемопередатчик RS-485 8-PDIP от -40 до 85
SN65HVD2x Extended Common-Mode RS-485 Transceivers datasheet
PDF, 1.3 Мб, Версия: F, Файл опубликован: 18 ноя 2016
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
Маркировка65HVD22
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Common Mode Range-20 to 25
DuplexHalf
Fail SafeIdle,Open,Short
Fault Protection-27 to 27 В
HBM ESD16 kV
ICC(Max)9 мА
IEC 61000-4-2 ContactN/A +/- kV
IsolatedNo
No. of RX1
No. of TX1
Number of Nodes256
Package GroupPDIP
Signaling Rate(Max)0.5 Mbps
Supply Voltage(s)(Nom)5 В
  • Evaluation Modules & Boards: SN65HVD22EVM
    SN65HVD22EVM Evaluation Module
  • Evaluation Modules & Boards: RS485-HF-DPLX-EVM
    RS-485 Half-Duplex Evaluation Module
  • RS-485 at 230-kbps Over Uncontrolled Interconnect
    PDF, 408 Кб, Файл опубликован: 12 апр 2004
    This application report presents an evaluation of the SN65LBC184, SN65HVD22, and MAX487 transceivers in an uncontrolled impedance interconnection signaling at 230 kbps. The network used for the evaluation was identified as typical of that for building security.
  • RS-485 for Digital Motor Control Applications
    PDF, 180 Кб, Файл опубликован: 12 май 2003
    This application report focuses on the benefits of using RS-485 signaling for motor control and motion control applications. This technology has several benefits for these applications in terms of noise immunity, wide common-mode voltage range, adequate data rate, and multipoint capability. Other applications also use RS-485 signaling to take advantage of these same benefits. Applications such as
  • The RS-485 Unit Load and Maximum Number of Bus Connections
    PDF, 197 Кб, Файл опубликован: 15 мар 2004
    The TIA/EIA-485 (RS-485) standard defines a Unit Load and confines bus configurations to 32. This report explains the Unit-Load concept and how it relates to the maximum number of bus connections. Fractional Unit-Load devices, such at the 1/8th Unit-Load SN65HVD21 and SN65HVD06, allow up to 256 devices on a single bus segment.
На английском языке: Datasheet Texas Instruments SN65HVD22P
