Datasheet Texas Instruments TPS60110PWPG4 — Даташит
СерияTPS60110
МодельTPS60110PWPG4
Регулируемый мощный малошумящий преобразователь постоянного тока в постоянный ток с напряжением 5 В 20-HTSSOP от -40 до 85
Regulated 5-V 300-mA Low-Noise Charge Pump DC/DC Converter datasheet
PDF, 993 Кб, Версия: C, Файл опубликован: 7 авг 2008
Pin20
Package TypePWP
Industry STD TermHTSSOP
Package QTY70
МаркировкаTPS60110
Width (мм)4.4
Length (мм)6.5
Thickness (мм)1
Max Height (мм)1.2
Iout(Max)0.3 A
Iq(Typ)0.05 мА
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization
Switching Frequency(Max)400 kHz
Switching Frequency(Min)200 kHz
ТипCharge Pump
Vin(Max)5.4 В
Vin(Min)2.7 В
Vout(Max)5 В
Vout(Min)5 В
  • Evaluation Modules & Boards: TPS60110EVM-132
    3 battery cells/1 Li-Ion cell to 5.0V, 300mA zero ripple charge pump EVM
  • Additional Negative Output with TPS601xx
    PDF, 64 Кб, Файл опубликован: 26 мар 2001
    In addition to a main positive supply voltage, some applications also require a negative voltage at low current. The power-supply circuit should easily be able to provide the application with this additional supply voltage. This note discusses a simple way to derive a negative voltage from a charge pump dc/dc converter. An easy solution to stabilize the negative voltage is to use a shunt regulator
  • TPS6010x/TPS6011x Charge Pump (Rev. A)
    PDF, 391 Кб, Версия: A, Файл опубликован: 16 дек 1999
    Charge pumps are dc/dc converters that use a capacitor instead of an inductor or transformer for energy storage. They are able to generate positive or negative voltages from the input voltage. The input voltage can be multiplied by some factor such as 0.5, 2, 3, and so on, to generate the output voltage desired. Often, charge pumps and all related parts (including those used for energy storage) ar
  • PowerPAD Thermally Enhanced Package (Rev. H)
    PDF, 983 Кб, Версия: H, Файл опубликован: 6 июл 2018
Серия: TPS60110 (4)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Charge Pump (Inductorless)
На английском языке: Datasheet Texas Instruments TPS60110PWPG4
