Datasheet ТI UCC2818AD — Даташит
| Серия | UCC2818A |
| Модель | UCC2818AD |
Предварительный регулятор коэффициента мощности BiCMOS 16-SOIC от -40 до 85
UCCx81xA BiCMOS Power Factor Preregulator datasheet
PDF, 1.1 Мб, Версия: D, Файл опубликован: 31 авг 2016
- PFC Pre-Regulator Frequency Dithering Circuit (Rev. A)PDF, 155 Кб, Версия: A, Файл опубликован: 14 май 2010
PFC Pre-Regulator Frequency Dithering Circuit - PFC Family Differences UCC3817A/18A/19A and UCC3817/18/19PDF, 32 Кб, Файл опубликован: 18 авг 2003
The UCC3817A/18A/19A family of PFC controllers (UCC3817A family) is pin for pin compatible with the UCC3817/18/19 family of devices (UCC3817 family). The output stage of UCC3817A family has been updated to allow use of a smaller external gate drive resistor values. For some power supply designs where an adequately high enough gate drive resistor can not be used, the UCC3817A family offers a more r - UCC3817 Current Sense Transformer EvaluationPDF, 49 Кб, Файл опубликован: 13 фев 2004
- Synchronizing a PFC Controller from a Down Stream Controller Gate DrivePDF, 103 Кб, Файл опубликован: 3 ноя 2000
Due to pending line harmonic requirements at higher power levels, power factor correction (PFC) is required in some ac-to-dc off-line power converter applications. This type of power converter can be designed with two cascaded power stages similar to the configuration in Figure 1. The first stage is a boost converter that converts the ac voltage to dc voltage with PFC. The output voltage of the bo - Bootstrap Circuit for Green Mode ApplicationsPDF, 111 Кб, Файл опубликован: 27 янв 2006
- Startup Current transient of the Leading Edge Triggered PFC ControllersPDF, 43 Кб, Файл опубликован: 30 июн 2004
- Avoiding Audible Noise at Light Loads When Using Leading Edge Triggered PFC Con (Rev. C)PDF, 57 Кб, Версия: C, Файл опубликован: 13 апр 2011
This application note applies to the TI average current mode, leading edge modulation PFC controllers. See Applicable Device Table for part numbers. - DN-66 UC3854A/B and UC3855A/B Provide Power Limiting with Sinusoidal Input (Rev. A)PDF, 80 Кб, Версия: A, Файл опубликован: 6 ноя 2001
- Accurate PWM Duty Cycle ClampPDF, 58 Кб, Файл опубликован: 25 янв 2002
Power supply applications using current sense transformers require a duty cycle clamp on the pulse width modulator (PWM) to ensure transformer reset. Not all PWMs come with a duty cycle clamp presenting a problem for the power supply designer. This application note shows how to implement a duty cycle clamp by using a simple delay circuit.
Серия: UCC2818A (9)
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
