Datasheet Texas Instruments SN74AS138N3 — Даташит
СерияSN74AS138
МодельSN74AS138N3
Декодеры/демультиплексоры с 3-8 строками 16-PDIP от 0 до 70
3-Line To 8-Line Decoders/Demultiplexers datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 1 июл 1996
Pin16
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Approx. Price (US$)1.35 | 1ku
Bits(#)8
Channels(#)1
Configuration3:8
F @ Nom Voltage(Max)(Mhz)125
FunctionDecoder/Demultiplexer
ICC @ Nom Voltage(Max)(mA)20
Тип входаTTL
Output Drive (IOL/IOH)(Max)(mA)20/-2
Тип выходаTTL
Package GroupPDIP
Schmitt TriggerNo
Technology FamilyAS
ТипStandard
VCC(Max)(V)5.5
VCC(Min)(V)4.5
Voltage(Nom)(V)5
tpd @ Nom Voltage(Max)(ns)22
RoHSНе совместим
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Semiconductors > Logic > Specialty Logic > Decoder/Encoder/Multiplexer
На английском языке: Datasheet Texas Instruments SN74AS138N3
