Datasheet Texas Instruments LM2735XSD/NOPB — Даташит
СерияLM2735
МодельLM2735XSD/NOPB
520 кГц/1,6 МГц — компактное усиление и стабилизатор постоянного тока SEPIC 6-WSON
LM2735-xx 520-kHz and 1.6-MHz Space-Efficient Boost and SEPIC DC-DC Regulator datasheet
PDF, 1.8 Мб, Версия: G, Файл опубликован: 31 авг 2015
Pin6
Package TypeNGG
Industry STD TermWSON
JEDEC CodeS-PDSO-N
Package QTY1000
CarrierSMALL T&R
Маркировка2735X
Width (мм)3
Length (мм)3
Thickness (мм).8
Pitch (мм).95
Max Height (мм).8
Iq(Typ)7 мА
Package GroupWSON
Regulated Outputs1
Special FeaturesEnable
Switch Current Limit(Typ)2.25 A
ТипConverter
Vin(Max)5.5 В
Vin(Min)2.7 В
Vout(Max)24 В
Vout(Min)3 В
  • Evaluation Modules & Boards: LM2735YMFEVAL
    520kHz 1.6MHz Space-Efficient Boost and SEPIC DC-DC Regulator LM2735Y Boost 5-Pin SOT23 Demo Board
  • Evaluation Modules & Boards: LM2735XSDEVAL
    520kHz 1.6MHz Space-Efficient Boost and SEPIC DC-DC Regulator LM2735X Boost 6-Pin LLP Demo Board
  • Evaluation Modules & Boards: LM2735YMYEVAL
    520kHz 1.6MHz Space-Efficient Boost and SEPIC DC-DC Regulator LM2735X Boost 8-Pin eMSOP Demo Board
  • Evaluation Modules & Boards: EVMX777G-01-20-00
    J6Entry/RSP Infotainment (CPU+Display+JAMR3) Evaluation Module
  • Evaluation Modules & Boards: LM2735XMFEVAL
    520kHz 1.6MHz - Space-Efficient Boost and SEPIC DC-DC Regulator LM2735X Boost 5-Pin SOT23 Demo Board
  • Evaluation Modules & Boards: LM2735YSDEVAL
    520kHz 1.6MHz Space-Efficient Boost and SEPIC DC-DC Regulator LM2735Y Boost 6-Pin LLP Demo Board
  • Evaluation Modules & Boards: EVMX777LCDTS-V1-0
    1280 X 800 Display and Touchscreen Daughter Board
  • Evaluation Modules & Boards: LM2735XMYEVAL
    520kHz 1.6MHz Space-Efficient Boost and SEPIC DC-DC Regulator LM2735Y Boost 8-Pin eMSOP Demo Board
  • Evaluation Modules & Boards: LM2735SD3.3EVAL
    520kHz 1.6MHz - Space-Efficient Boost and SEPIC DC-DC Regulator LM2735X SEPIC 6-Pin LLP Demo Board
  • Design of UVLO for LM27313 (Rev. B)
    PDF, 142 Кб, Версия: B, Файл опубликован: 8 апр 2014
  • AN-1658 LM2735 BOOST and SEPIC DC-DC Regulator (Rev. A)
    PDF, 373 Кб, Версия: A, Файл опубликован: 23 апр 2013
    This report discusses the features and use of the LM2735 Boost and SEPIC DC-DC Regulator.
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments LM2735XSD/NOPB
