Datasheet Texas Instruments SN74LVC2244APWRE4 — Даташит
| Серия | SN74LVC2244A |
| Модель | SN74LVC2244APWRE4 |
Восьмеричный буфер/драйвер с выходами с 3 состояниями 20-TSSOP от -40 до 85
SN74LVC2244A Octal Buffer/Driver With 3-State Outputs datasheet
PDF, 1.3 Мб, Версия: L, Файл опубликован: 3 июл 2014
Купить SN74LVC2244APWRE4 на РадиоЛоцман.Цены — от 8.41 до 100 ₽16 предложений от 13 поставщиков IC BUF NON-INVERT 3.6V 20TSSOP. Buffer, Non-Inverting 2 Element 4 Bit per Element 3-State Output 20-TSSOP. Logic - Buffers, Drivers, Receivers,... | |||
| SN74LVC2244APWRE4 Texas Instruments | 15 ₽ | ||
| SN74LVC2244APWRE4 Texas Instruments | 17 ₽ | ||
| SN74LVC2244APWRE4 Texas Instruments | по запросу | ||
| Pin | 20 |
| Package Type | PW |
| Industry STD Term | TSSOP |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2000 |
| Carrier | LARGE T&R |
| Маркировка | LE244A |
| Width (мм) | 4.4 |
| Length (мм) | 6.5 |
| Thickness (мм) | 1 |
| Pitch (мм) | .65 |
| Max Height (мм) | 1.2 |
| Mechanical Data | Скачать |
| Bits | 8 |
| F @ Nom Voltage(Max) | 100 Mhz |
| ICC @ Nom Voltage(Max) | 0.01 мА |
| Output Drive (IOL/IOH)(Max) | -12/12 мА |
| Package Group | TSSOP |
| Package Size: mm2:W x L | 20TSSOP: 42 mm2: 6.4 x 6.5(TSSOP) PKG |
| Rating | Catalog |
| Schmitt Trigger | No |
| Technology Family | LVC |
| VCC(Max) | 3.6 В |
| VCC(Min) | 1.65 В |
| Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
| tpd @ Nom Voltage(Max) | 10.9,7.9,6.4,5.5 нс |
Серия: SN74LVC2244A (20)
- SN74LVC2244ADBLE SN74LVC2244ADBQR SN74LVC2244ADBQRE4 SN74LVC2244ADBR SN74LVC2244ADBRG4 SN74LVC2244ADGVR SN74LVC2244ADGVRE4 SN74LVC2244ADW SN74LVC2244ADWR SN74LVC2244ADWRE4 SN74LVC2244ADWRG4 SN74LVC2244ANSR SN74LVC2244ANSRG4 SN74LVC2244APW SN74LVC2244APWG4 SN74LVC2244APWLE SN74LVC2244APWR SN74LVC2244APWRE4 SN74LVC2244APWRG4 SN74LVC2244APWT
- Semiconductors > Logic > Buffer/Driver/Transceiver > Non-Inverting Buffer/Driver
