Datasheet Texas Instruments TMS320C5515AZCHA12 — Даташит
СерияTMS320C5515
МодельTMS320C5515AZCHA12
Процессор цифровых сигналов с фиксированной точкой 196-NFBGA от -40 до 85
TMS320C5515 Fixed-Point Digital Signal Processor datasheet
PDF, 1.1 Мб, Версия: F, Файл опубликован: 21 окт 2013
Pin196
Package TypeZCH
Industry STD TermNFBGA
JEDEC CodeS-PBGA-N
Package QTY184
Маркировка15AZCHA12
Width (мм)10
Length (мм)10
Thickness (мм).89
Max Height (мм)1.3
ApplicationsCommunications and Telecom,Industrial,Medical
DRAMSDRAM,mSDRAM
DSP1 C55x
DSP MHz100,120 Max.
I2C1
Operating SystemsDSP/BIOS,VLX
Рабочий диапазон температурот -10 до 70,-40 до 85 C
Other Hardware AccelerationFFT Coprocessor
SPI1
UART1 SCI
USB1
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-14T
    XDS100v2 JTAG Debug Probe (14-pin TI version)
  • JTAG Emulators/ Analyzers: TMDSEMU100V2U-20T
    XDS100v2 JTAG Debug Probe (20-pin cTI version)
  • Development Kits: TMDXEVM5515
    TMS320C5515 DSP Evaluation Module
  • Evaluation Modules & Boards: TMDX5515EZDSP
    C5515 eZDSP USB Stick Development Tool
    XDS200 USB Debug Probe
  • Pulse Oximeter Implementation on the TMS320C5515 DSP Medical Development Kit (Rev. A)
    PDF, 1.9 Мб, Версия: A, Файл опубликован: 29 июн 2010
    The medical development kit (MDK) provides a development platform to TI medical customers, third parties, and other developers. This application report focuses on the C5515 MDK; however, the analog front ends that are included can also be used with other platforms.Please be aware that an important notice concerning availability, standard warranty, and use in critical applications of Texas Ins
  • Digital Stethoscope Implementation on TMS320C5515 DSP Medical Development Kit (Rev. A)
    PDF, 1.3 Мб, Версия: A, Файл опубликован: 29 июн 2010
  • Migrating from TMS320C5515 to 5517
    PDF, 144 Кб, Файл опубликован: 2 апр 2014
    The TMS320C5515 and the TMS320C5505 will henceforth in this document be referred to as C5515/05. The TMS320C5517 will henceforth in this document be referred to as C5517.This document provides the minimum changes required to migrate from the C5515/05 to the C5517. Enhancements or new features of the C5517 that do not affect migrating from the C5515/05 to the C5517 are also briefly mentioned in
  • ECG Implementation on the TMS320C5515 DSP Medical Development Kit (Rev. B)
    PDF, 1.5 Мб, Версия: B, Файл опубликован: 29 июн 2010
  • FFT Implementation on the TMS320VC5505, TMS320C5505, and TMS320C5515 DSPs (Rev. B)
    PDF, 392 Кб, Версия: B, Файл опубликован: 9 янв 2013
    The Fast Fourier Transform (FFT) is an efficient means for computing the Discrete Fourier Transform (DFT). It is one of the most widely used computational elements in Digital Signal Processing (DSP) applications. This DSP is ideally suited for such applications. They include an FFT hardware accelerator (HWAFFT) that is tightly coupled with the CPU, allowing high FFT processing performance at very
  • Usage Guidelines for C55x On-Chip Low Dropout Regulators (LDOs)
    PDF, 220 Кб, Файл опубликован: 26 июл 2016
    The C5515/C5535/C5545/C5517 devices include three low dropout regulators ANA_LDO, DSP_LDO and USB_LDO. This application report provides the guidelines for using these on-chip low dropout regulators. This document also covers the USB power-up sequence that must be followed when using the device USB.
  • Using the TMS320C5515/14/05/04 Bootloader (Rev. C)
    PDF, 1.8 Мб, Версия: C, Файл опубликован: 15 июл 2015
  • MEMS Microphone Direct PDM Input via I2S to a C5515 EVM With Software Decimation
    PDF, 686 Кб, Файл опубликован: 22 сен 2016
    This application report helps system designers demonstrate and understand the technique of directly feeding a MEMS mic output PDM stream into the Inter-IC Sound (I2S) lines of a C5515 EVM. This document is intended for audiences familiar with Digital Signal Processing, decimation and filtering techniques.
  • Instructions to Benchmark C55 DSP Library
    PDF, 3.2 Мб, Файл опубликован: 1 апр 2016
    DSP Library (DSPLIB) is a collection of optimized C55x assembly functions that implement a wide variety of DSP functions. The TMS320C55x DSP Library Programmer’s Reference User's Guide provides cycle estimation for the execution of each function in the library. This work enables the user to measure the performances of a sub-set of the DSPLIB functions executed on real hardware, and with some addit
  • Migrating from TMS320C5515/05 to TMS320C5535/34/33/32 (Rev. A)
    PDF, 352 Кб, Версия: A, Файл опубликован: 22 дек 2011
    This document provides the minimum changes required to migrate from TMS320C5515/05 to TMS320C5535/34/33/32. Enhancements or new features of the TMS320C5535/34/33/32 devices that do not affect migrating from the TMS320C5515/05 devices will also be briefly mentioned in this document.All efforts have been made to provide a comprehensive list of changes. An update will be provided if additional c
  • C5000 DSP-Based Low-Power System Design
    PDF, 169 Кб, Файл опубликован: 30 ноя 2015
    Low-power consumption is one of the most important requirements for the embedded system. The C5000в„ў ultra low-power DSP family is ideal for portable devices (audio, voice and vision) and other applications that require analytics with low power.To take advantage of this feature in system design, good practices need to be carried out. This application report focuses on the Texas Instrum
  • Power Estimation and Pwr Consumption Sum for TMS320C5504/05/14/15/32/33/34/35/45 (Rev. A)
    PDF, 555 Кб, Версия: A, Файл опубликован: 4 апр 2016
    This application report assists in estimating the power consumption for the TMS320C5515, C5504, C5505, C5514, C5532, C5533, C5534, C5535 and C5545 devices (DSPs), using a power estimation spreadsheet.
  • Semiconductors > Processors > Digital Signal Processors > C5000 DSP > C55x DSP
На английском языке: Datasheet Texas Instruments TMS320C5515AZCHA12
