Datasheet Texas Instruments OPA177GS/2K5G4 — Даташит
СерияOPA177
МодельOPA177GS/2K5G4
Прецизионный операционный усилитель 8-SOIC
Precision Operational Amplifier datasheet
PDF, 296 Кб, Файл опубликован: 27 сен 2000
Pin88
Package TypeDD
Industry STD TermSOICSOIC
JEDEC CodeR-PDSO-GR-PDSO-G
Package QTY25002500
CarrierLARGE T&RLARGE T&R
Маркировка177GSOPA
Width (мм)3.913.91
Length (мм)4.94.9
Thickness (мм)1.581.58
Pitch (мм)1.271.27
Max Height (мм)1.751.75
Additional FeaturesN/A
АрхитектураFET
CMRR(Min)115 дБ
CMRR(Typ)140 дБ
GBW(Typ)0.6 МГц
Input Bias Current(Max)2000 pA
Iq per channel(Max)2 мА
Iq per channel(Typ)1.3 мА
Количество каналов1
Offset Drift(Typ)0.1 uV/C
Output Current(Typ)22 мА
Rail-to-RailOut
Slew Rate(Typ)0.3 V/us
Total Supply Voltage(Min)6 +5V=5, +/-5V=10
Vn at 1kHz(Typ)7.5 нВ/rtГц
Vos (Offset Voltage @ 25C)(Max)0.025 мВ
  • Diode-Based Temperature Measurement
    PDF, 44 Кб, Файл опубликован: 27 сен 2000
    Diodes are frequently used as temperature sensors in a wide variety of moderate-precision temperature measurement applications. The relatively high temperature coefficient of about -2mV/В°C is fairly linear. To make a temperature measurement system with a diode requires excitation, offsetting, and amplification. The circuitry can be quite simple. This Bulletin contains a collection of circuits
  • Tuning in Amplifiers
  • Compensate Transimpedance Amplifiers Intuitively (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 30 мар 2005
    Transimpedance amplifiers are used to convert low-level photodiode currents to usable voltage signals. All too often, the amplifiers have to be empirically compensated to operate properly. The problem can be easily understood if one looks at all the elements involved.
  • Boost Instrument Amp CMR With Common-Mode Driven Supplies
    PDF, 175 Кб, Файл опубликован: 27 сен 2000
    Ever-increasing demands are being placed on instrumentation amplifier (IA) performance. When standard IAs can not deliver the required performance, consider this enhanced version. Dramatic performance improvements can be achieved by operating the input amplifiers of a classical three-op-amp IA from common-mode driven sub-regulated power supplies.
  • Op Amp Performance Analysis
На английском языке: Datasheet Texas Instruments OPA177GS/2K5G4
