Datasheet ТI TLV2772IDGK — Даташит
| Серия | TLV2772 |
| Модель | TLV2772IDGK |
Двойной операционный усилитель Rail-To-Rail с высокой скоростью нарастания напряжения 2,7 В и выходом 8-VSSOP от -40 до 125
2.7-V High-Slew-Rate Rail-to-Rail Output Op Amps w/ Shutdown datasheet
PDF, 2.5 Мб, Версия: G, Файл опубликован: 23 фев 2004
- 3-V Accelerometer Featuring TLV2772PDF, 219 Кб, Файл опубликован: 31 авг 1998
This paper describes a complete solution for digital measurement of acceleration. An AMP accelerometer sensor is used for the conversion between mechanical acceleration and electrical analog. This electrical signal is then conditioned using Texas Instruments? TLV2772 op amp (on the Universal Op Amp EVM), digitized using the TLV1544 ADC EVM, and processed with the TMS320C5X EVM. This provides the u - 3 V Accelerometer Featuring TLV2772 Application BriefPDF, 56 Кб, Файл опубликован: 23 ноя 1998
This application brief describes a 3-axis acceleration data collection system that uses a TLV2772 operational amplifier to amplify and filter sensor electrical signals. Use of the available evaluation modules from Texas Instruments allows for easy construction of the system for evaluation. - Evaluating the TLV2462 and TLV2772 as Drive Amps for the TLV2544/TLV2548 ADCPDF, 63 Кб, Файл опубликован: 26 июн 2000
This report presents a method for comparing the ac performance of the TLV2462 and TLV2772 operational amplifiers to the ac performance of the TLV2544/TLV2548 analog-to-digital converter. - TLV277x/TLV277xA EMI Immunity PerformancePDF, 284 Кб, Файл опубликован: 20 дек 2012
- Stability Analysis Of Voltage-Feedback Op Amps Including Compensation Technique (Rev. A)PDF, 197 Кб, Версия: A, Файл опубликован: 12 мар 2001
This report presents an analysis of the stability of voltage-feedback operational amplifiers (op amps) using circuit performance as the criteria to attain a successful design. It discusses several compensation techniques for op amps with and without internal compensation. - Use of Rail-to-Rail Operational Amplifiers (Rev. A)PDF, 159 Кб, Версия: A, Файл опубликован: 22 дек 1999
Серия: TLV2772 (24)
