Datasheet Texas Instruments DAC121C081CIMK/NOPB — Даташит
СерияDAC121C081
МодельDAC121C081CIMK/NOPB
12-битный микромощный цифро-аналоговый преобразователь с I2C-совместимым интерфейсом 6-SOT-23-THIN от -40 до 125
DAC121C081 and DAC121C085 12-Bit Micro Power Digital-to-Analog Converter With an I2C-Compatible Interface datasheet
PDF, 1.8 Мб, Версия: F, Файл опубликован: 3 окт 2016
Pin6
Package TypeDDC
Industry STD TermSOT-23-THIN
Package QTY1000
МаркировкаX84C
Width (мм)1.6
Length (мм)2.9
Thickness (мм).87
Pitch (мм).95
Max Height (мм)1.1
Code to Code Glitch(Typ)12 nV-sec
DAC ArchitectureString
DAC Channels1
Gain Error(Max)0.7 %FSR
INL(Max)8 +/-LSB
InterfaceI2C
Output Range Max.5.5 mA/V
Тип выходаBuffered Voltage
Package GroupSOT-23-THIN
Package Size: mm2:W x L6SOT-23-THIN: 8 mm2: 2.8 x 2.9(SOT-23-THIN) PKG
Power Consumption(Typ)0.38 mW
Reference: TypeExt
Разрешение12 Bits
Sample / Update Rate0.18 MSPS
Время установления8.5 µs
Special FeaturesN/A
Zero Code Error(Typ)10 мВ
  • Evaluation Modules & Boards: DAC121C085EVM
    DAC121C085 Evaluation Module
  • AN-2001 Daisy Chaining Precision DACs (Rev. A)
    PDF, 75 Кб, Версия: A, Файл опубликован: 1 май 2013
    It is not uncommon for the system designer to face a quagmire of reconciling the system complexity withthe desire to keep the system footprint small. One specific example that often arises in the context ofsmall system footprint is the need for single master controller to communicate with a number of slavedevices. This is not much of a problem if the master controller has multiple I/O resour
На английском языке: Datasheet Texas Instruments DAC121C081CIMK/NOPB
