Datasheet Texas Instruments TPS76328DBV — Даташит
СерияTPS763
МодельTPS76328DBV
Линейные регуляторы с низким Iq, 150 мА, с низким падением напряжения 5-SOT-23
TPS763 Low-Power 150-mA Low-Dropout Linear Regulators datasheet
PDF, 1.0 Мб, Версия: I, Файл опубликован: 23 дек 2016
Pin5
Package TypeDBV
Industry STD TermSOT
Width (мм)1.6
Length (мм)2.9
Thickness (мм)1.2
Pitch (мм).95
Max Height (мм)1.45
Accuracy(%)3
Additional FeaturesEnable
Overcurrent Protection
Thermal Shutdown
Approx. Price (US$)0.28 | 1ku
Fixed Output Options(V)1.6
1.8
2.5
2.7
2.8
3
3.3
3.8
5
Iout(Max)(A)0.15
Iq(Typ)(mA)0.08
Operating Temperature Range(C)-40 to 125
Output OptionsAdjustable Output
Fixed Output
PSRR @ 100KHz(dB)41
Package GroupSOT-23
Package Size: mm2:W x L (PKG)5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23)
Regulated Outputs(#)1
Vdo(Typ)(mV)375
Vin(Max)(V)10
Vin(Min)(V)2.7
Vout(Max)(V)5
Vout(Min)(V)1.5
RoHSНе совместим
  • Evaluation Modules & Boards: TPS76XXXEVM-125
    TPS76xxxEVM-125 Universal SOT-23 LDO Evaluation Module
  • Evaluation Modules & Boards: DEM-SOT23LDO
    DEM-SOT23LDO Compatible with Most Positive-Output LDO Regulators in 5- or 6-Lead SOT23 (DBV) Pkg
  • Interfacing high-voltage applications to low-power controllers
    PDF, 552 Кб, Файл опубликован: 15 ноя 2010
  • Isolated RS-485 transceivers support DMX512 stage lighting & special-effects app
    PDF, 143 Кб, Файл опубликован: 16 сен 2011
  • Low Power 150-mA LDO Linear Regulators. Extended Output Voltage Adjustment Range
    PDF, 41 Кб, Файл опубликован: 11 июн 1999
    The TPS76301 low-dropout (LDO) adjustable linear regulator generates a regulated 1-V output from an input voltage ranging from 3 V to 6 V. The application circuit is based on the application detailed in the TPS76301 data sheet (TI Literature number SLVS181A Figure 21) except for the auxiliary circuit which is shown here in Figure 1.
  • TPS6010x/TPS6011x Charge Pump (Rev. A)
    PDF, 391 Кб, Версия: A, Файл опубликован: 16 дек 1999
    Charge pumps are dc/dc converters that use a capacitor instead of an inductor or transformer for energy storage. They are able to generate positive or negative voltages from the input voltage. The input voltage can be multiplied by some factor such as 0.5, 2, 3, and so on, to generate the output voltage desired. Often, charge pumps and all related parts (including those used for energy storage) ar
  • 3Q 2011 Issue Analog Applications Journal
    PDF, 1.4 Мб, Файл опубликован: 16 сен 2011
  • Журнал РїРѕ применению аналоговых компонентов 3Q 2011
    PDF, 3.9 Мб, Файл опубликован: 1 сен 2011
На английском языке: Datasheet Texas Instruments TPS76328DBV
