Datasheet Texas Instruments TL431CLPB-TDJ — Даташит
СерияTL431
МодельTL431CLPB-TDJ
Регулируемый прецизионный шунтирующий регулятор 3-TO-92 от 0 до 75
Datasheet TL431, TL431A, TL431B, TL432, TL432A, TL432B
PDF, 2.9 Мб, Версия: O, Файл опубликован: 29 янв 2015, Страниц: 78
TL43xx Precision Programmable Reference
Pin3
Package TypeLP
Industry STD TermTO-92
JEDEC CodeO-PBCY-W
Width (мм)4.3
Length (мм)4.3
Thickness (мм)3.6
Max Height (мм)5.34
Approx. Price (US$)0.06 | 1ku
Initial Accuracy(Max)(%)2
Iout/Iz(Max)(mA)100
Min Iz for Regulation(uA)400
Operating Temperature Range(C)-40 to 125
-40 to 85
0 to 70
Package GroupTO-92
See datasheet (PFM)
See datasheet (CDIP)
Pin/Package0WAFERSALE
3SOT-23
3SOT-89
5SOT-23
6SC70
8PDIP
8SO
8SOIC
3TO-92
8TSSOP
Reference VoltageAdjustable
Temp Coeff(Max)(ppm/ degree C)92
Temp Coeff(Typ)(ppm/ degree C)34
VO Adj(Max)(V)36
VO Adj(Min)(V)2.495
VO(V)2.495
RoHSНе совместим
  • Q1 2009 Issue Analog Applications Journal
    PDF, 1.4 Мб, Файл опубликован: 11 мар 2009
  • Designing Overcurrent protection for TPL7407L Peripheral Driver
    PDF, 177 Кб, Файл опубликован: 5 ноя 2014
    Microcontroller units (MCUs) are generally limited with lower drive on the I/Os. Most of the applicationsrequiring MCU boards to drive high-current loads need discrete implementation and additional components which use a lot of board space. This board space is called a peripheral driver section. The TPL7407L device is an integrated peripheral driver with seven channel drivers inside. The TPL740
  • Using a portable-power boost converter in an isolated flyback application
    PDF, 535 Кб, Файл опубликован: 11 мар 2009
  • Setting the shunt voltage on an adjustable shunt regulator
    PDF, 170 Кб, Файл опубликован: 1 сен 2011
  • Understanding stability boundary conditions charts in TL431 TL432 Data sheet (Rev. A)
    PDF, 386 Кб, Версия: A, Файл опубликован: 16 янв 2014
  • Compensation Design with TL431 for UCC28600
    PDF, 542 Кб, Файл опубликован: 16 янв 2013
  • Lead-Acid Charger and LED Driver using TPS5402 (Rev. A)
    PDF, 210 Кб, Версия: A, Файл опубликован: 13 июн 2013
    The TPS5402 device is a non-synchronous buck regulator with a wide operating range from 3.5 to 28 V.The switching frequency of the converters can be set from 50 kHz to 1.1 MHz with an external resistor.Frequency-spread spectrum operation is introduced for EMI reduction. TPS5402 supports pulse-skippingmode to enhance the efficiency at light load making this device an ideal pick for applicati
  • Designing Switching Voltage Regulators With the TL494 (Rev. E)
    PDF, 329 Кб, Версия: E, Файл опубликован: 26 июл 2005
  • Low-cost flyback solutions for 10-mW standby power
    PDF, 237 Кб, Файл опубликован: 22 янв 2014
TL431CLPBTDJ, TL431CLPB TDJ
На английском языке: Datasheet Texas Instruments TL431CLPB-TDJ
