Datasheet Texas Instruments UCC38C41P — Даташит
| Серия | UCC38C41 |
| Модель | UCC38C41P |
ШИМ-контроллер BiCMOS с малым током 8-PDIP 0–70
UCCx8C4x BiCMOS Low-Power Current-Mode PWM Controller datasheet
PDF, 3.8 Мб, Версия: G, Файл опубликован: 10 янв 2017
Купить UCC38C41P на РадиоЛоцман.Цены — от 31 до 811 ₽16 предложений от 16 поставщиков IC REG CTRLR MULT TOPOLOGY 8DIP. Boost, Flyback, Forward Converter Regulator Positive Output Step-Up, Step-Up/Step-Down DC-DC Controller IC 8-PDIP. PMIC -... | |||
| UCC38C41P Texas Instruments | 67 ₽ | ||
| UCC38C41P Texas Instruments | 811 ₽ | ||
| UCC38C41P Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | P |
| Industry STD Term | PDIP |
| JEDEC Code | R-PDIP-T |
| Package QTY | 50 |
| Carrier | TUBE |
| Маркировка | UCC38C41P |
| Width (мм) | 6.35 |
| Length (мм) | 9.81 |
| Thickness (мм) | 3.9 |
| Pitch (мм) | 2.54 |
| Max Height (мм) | 5.08 |
| Mechanical Data | Скачать |
| Control Method | Peak Current Mode |
| Duty Cycle(Max) | 50 % |
| Frequency(Max) | 1000 kHz |
| Frequency(Min) | 26 kHz |
| Gate Drive(Typ) | 1 A |
| Рабочий диапазон температур | от 0 до 70 C |
| Package Group | PDIP |
| Rating | Catalog |
| Special Features | Error Amplifier,Multi-topology |
| Topology | Boost,Buck,Buck-Boost,Flyback,Forward |
| UVLO Thresholds On/Off | 7/6.6 В |
| Vin(Max) | 400 В |
| Vin(Min) | 7 В |
- UCC38C44 12-V Isolated Bias Supply (Rev. A)PDF, 324 Кб, Версия: A, Файл опубликован: 9 окт 2008
This reference design describes a discontinuous, peak current-mode flyback converter whose input voltage is generated from the output of a universal power factor correction circuit. The converter is designed to operate at a switching frequency of 225 kHz, requires minimal parts, and supports an isolated 12-V, 3-W output and a non-isolated 12-V, 1-W output ideally suited for chip bias and voltage f - UCC38C42 25-W Forward ConverterPDF, 320 Кб, Файл опубликован: 6 сен 2002
This reference design presents a self-resonant reset forward converter using the UCC38C42 BiCMOS Low-Power Current-Mode PWM Controller. The input voltage for this converter is compatible with the telecom input voltage range of 36 VDC to 72 VDC. The converter is designed to operate at a switching frequency of 525 kHz, requires minimal parts, and supports an isolated 2.5-V 10-A output. The complete - UCC38C42 Family of High-Speed BiCMOS Current-Mode PWM ControllersPDF, 280 Кб, Файл опубликован: 7 фев 2002
Since their introduction in the mid 1980?s the bipolar UC3842 family of Pulse width modulation (PWM)controllers has grown to become the most widely-used control strategy in the power supply industry. [1] The reasons for success are quite clear the devices feature an elegantly simple yet very effective control architecture they use only 8 pins they can drive MOSFET gates directly and they offer - U-111 Practical Considerations in Current Mode Power SuppliesPDF, 787 Кб, Файл опубликован: 5 сен 1999
This application note explains the numerous PWM functions and ways to maximize their usefulness. It covers practical circuit design considerations such as slope compensation gate drive circuitry external control functions synchronization and paralleling current-mode controlled modules. Circuit diagrams and simplified equations are included. - DN-42A Design Considerations for Transitioning from UC3842 to the New UCC3802PDF, 42 Кб, Файл опубликован: 5 сен 1999
The UCC3802 offers numerous advantages that allow the power supply design engineer to meet requirements for lower power for battery-operated equipment higher switching frequencies for reduced magnetics size higher levels of circuit integration for improved reliability and lower cost. The UCC3802 family of devices is pin-out compatible with the UC3842 and UC3842A families; however it is not plu - Conditioning a Switch-mode Power Supply Current Signal Using TI Op AmpsPDF, 61 Кб, Файл опубликован: 23 мар 2000
The switch-mode power supply primary current is often sensed using a power resistor. Using an op amp to amplify the current-sense signal can reduce cost and improve noise performance and efficiency. This report reviews the advantages of using an op amp circuit and analyzes the design criteria needed to choose the proper op amp. - Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
Серия: UCC38C41 (6)
- UCC38C41D UCC38C41DGK UCC38C41DGKG4 UCC38C41DR UCC38C41DRG4 UCC38C41P
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
