Datasheet Texas Instruments LM94022QBIMG/NOPB — Даташит
СерияLM94022-Q1
МодельLM94022QBIMG/NOPB
Automotive Grade, В±1.5В°C Temperature Sensor with Multiple Gain and Class-AB Analog Output 5-SC70 -50 to 150
LM94022/-Q1 1.5-V, SC70, Multi-Gain Analog Temperature Sensor With Class-AB Output datasheet
PDF, 1.2 Мб, Версия: F, Файл опубликован: 29 сен 2015
Pin5
Package TypeDCK
Industry STD TermSOT-SC70
Package QTY1000
Маркировка22Q
Width (мм)1.25
Length (мм)2
Thickness (мм).9
Max Height (мм)1.1
InterfaceAnalog Output
Local Sensor Accuracy(Max)1.5 +/- C
Рабочий диапазон температурот -50 до 150 C
Output Impedance5.2 Ohm
Package GroupSC70
Package Size: mm2:W x L5SC70: 4 mm2: 2.1 x 2(SC70) PKG
RatingAutomotive
Sensor Gain-5.5 to -13.6 mV/Deg C
Special FeaturesSelectable gain setting
Supply Current(Max)8.1 uA
Supply Voltage(Max)5.5 В
Supply Voltage(Min)1.5 В
  • AN-1952 Designing with Thermocouples (Rev. A)
    PDF, 72 Кб, Версия: A, Файл опубликован: 7 май 2013
    In 1821 Thomas Seebeck discovered the physical phenomenon that when you join two dissimilar metalson both ends and heat one end, a continuous current is created in the thermoelectric circuit . If the otherend is broken, a voltage can be measured that is proportional to the temperature difference between theheated junction (measuring or hot junction) and the open end (reference or cold ju
  • Low-Voltage Current Loop Transmitter
    PDF, 519 Кб, Файл опубликован: 2 авг 2007
Серия: LM94022-Q1 (2)
  • Semiconductors > Sensing Products > Temperature Sensors > Local Analog Temperature Sensors
На английском языке: Datasheet Texas Instruments LM94022QBIMG/NOPB
Публикации по теме
