Линейка продуктов KEEN SIDE
Datasheet Texas Instruments ADS774KU — Даташит
СерияADS774
МодельADS774KU
Совместимый с микропроцессором КМОП аналого-цифровой преобразователь 28-SOIC от -40 до 85
Microprocessor-Compatible Sampling CMOS A/D Converter datasheet
PDF, 935 Кб, Файл опубликован: 27 сен 2000
Pin28
Package TypeDW
Package QTY20
МаркировкаADS774KU
Width (мм)7.5
Length (мм)17.9
Thickness (мм)2.35
Max Height (мм)2.65
# Input Channels1
Analog Voltage AVDD(Max)5.5 В
Analog Voltage AVDD(Min)4.5 В
АрхитектураSAR
Digital Supply(Max)5.5 В
Digital Supply(Min)4.5 В
INL(Max)0.5 +/-LSB
Input Range(Max)10 В
Input Range(Min)-10 В
Тип входаSingle-Ended
Integrated FeaturesN/A
InterfaceParallel
Multi-Channel ConfigurationN/A
Package Size: mm2:W x L28SOIC: 184 mm2: 10.3 x 17.9(SOIC) PKG
Power Consumption(Typ)75 mW
Reference ModeExt,Int
Разрешение12 Bits
SINADN/A дБ
SNR72 дБ
Sample Rate (max)117kSPS SPS
Sample Rate(Max)0.117 MSPS
THD(Typ)-77 дБ
  • CDAC Architecture Gives ADC574 Pinout /Sampling, Low Power, New Input Ranges
    PDF, 54 Кб, Файл опубликован: 27 сен 2000
    This application note compares basic current-mode successive approximation A/Ds with CDAC-based architectures, and shows how adding a resistor divider network to the CDAC input permits the Burr-Brown ADS574 and ADS774 to fit existing ADC574 sockets. It then goes on to descibe some new analog input voltage ranges available on these parts due to the resistor network and CDAC approach.
  • Complete Temp Data Acquisition System From a Single +5V Supply
    PDF, 68 Кб, Файл опубликован: 2 окт 2000
    The CMOS ADS574 and ADS774 are drop-in replacements for industry standard ADC574 analog-to-digital converter, offering lower power and the capability to operate from a single +5V supply. The switched capacitor array architecture (CDAC), with the input resistor divider network to provide ADC574 input ranges, also allow the new parts to handle additional input ranges, including a 0V to 5V range. Thi
  • Determining Minimum Acquisition Times for SAR ADCs, part 1 (Rev. A)
    PDF, 227 Кб, Версия: A, Файл опубликован: 10 ноя 2010
    This application report analyzes a simple method for calculating minimum acquisition times for successive-approximation register analog-to-digital converters (SAR ADCs). The input structure of the ADC is examined along with the driving circuit. The voltage on the sampling capacitor is then determined for the case when a step function is applied to the input of the driving circuit. Three different
  • Analog-to-Digital Converter Grounding Practices Affect System Performance (Rev. A)
    PDF, 69 Кб, Версия: A, Файл опубликован: 18 май 2015
  • A Glossary of Analog-to-Digital Specifications and Performance Characteristics (Rev. B)
    PDF, 425 Кб, Версия: B, Файл опубликован: 9 окт 2011
    This glossary is a collection of the definitions of Texas Instruments' Delta-Sigma (О”ОЈ), successive approximation register (SAR), and pipeline analog-to-digital (A/D) converter specifications and performance characteristics. Although there is a considerable amount of detail in this document, the product data sheet for a particular product specification is the best and final reference.
  • Principles of Data Acquisition and Conversion (Rev. A)
    PDF, 132 Кб, Версия: A, Файл опубликован: 16 апр 2015
На английском языке: Datasheet Texas Instruments ADS774KU
