Линейка продуктов KEEN SIDE
Datasheet Texas Instruments TPS62140RGTT — Даташит
СерияTPS62140
МодельTPS62140RGTT
3–17V 2A Step-Down Converter with DCS-Control in 3x3 QFN package 16-VQFN -40 to 125
TPS6214x 3-V to 17-V 2-A Step-Down Converter in 3 Г— 3 QFN Package datasheet
PDF, 1.9 Мб, Версия: E, Файл опубликован: 12 сен 2016
Pin16
Package TypeRGT
Industry STD TermVQFN
JEDEC CodeS-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаQTZ
Width (мм)3
Length (мм)3
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
Control ModeConstant on-time (COT)
Duty Cycle(Max)100 %
Iout(Max)2 A
Iq(Typ)0.017 мА
Package GroupVQFN
Regulated Outputs1
Special FeaturesEnable,Light Load Efficiency,Output Discharge,Over Current Protection,Power Good,Pre-Bias Start-Up,Synchronous Rectification,Tracking,UVLO Fixed,Voltage Margining
Switching Frequency(Max)2500 kHz
Switching Frequency(Min)1250 kHz
Switching Frequency(Typ)2500 kHz
ТипConverter
Vin(Max)17 В
Vin(Min)3 В
Vout(Max)6.3 В
Vout(Min)0.9 В
  • Evaluation Modules & Boards: TPS62140EVM-505
    Evaluation Module for TPS62140 a 2-A, synchronous, step-down converter in a 3x3-mm, 16-pin QFN
  • Using the TPS62150 in a Split Rail Topology
    PDF, 429 Кб, Файл опубликован: 26 мар 2014
  • Voltage Margining Using the TPS62130
    PDF, 79 Кб, Файл опубликован: 15 дек 2011
    Voltage margining is a means of verifying the robustness of a product by intentionally adjusting its supply voltages to their limits and then evaluating the product’s performance to ensure that it still meets its specifications at the power supply’s extremes. The TPS62130 synchronous step-down dc-dc converter features an integrated output voltage scaling function that allows for +5% margining by u
  • TPS62130A Differences to TPS62130
    PDF, 247 Кб, Файл опубликован: 2 апр 2014
  • Step-Down LED Driver With Dimming With the TPS621-Family and TPS821-Family (Rev. A)
    PDF, 284 Кб, Версия: A, Файл опубликован: 28 июн 2017
  • Feedforward Capacitor to Improve Stability and Bandwidth of TPS621/821-Family (Rev. A)
    PDF, 720 Кб, Версия: A, Файл опубликован: 28 июн 2017
  • Sequencing and Tracking With the TPS621-Family and TPS821-Family (Rev. A)
    PDF, 210 Кб, Версия: A, Файл опубликован: 28 июн 2017
  • Step-Down Converter with Cable Voltage Drop Compensation
    PDF, 441 Кб, Файл опубликован: 26 июн 2014
  • Step-Down Converter With Input Overvoltage Protection
    PDF, 274 Кб, Файл опубликован: 4 сен 2014
    TPS62130 Step-Down Converter with Input Overvoltage Protection
  • Optimizing the TPS62130/40/50/60 Output Filter (Rev. A)
    PDF, 336 Кб, Версия: A, Файл опубликован: 15 июл 2015
  • Using the TPS6215x in an Inverting Buck-Boost Topology.. (Rev. C)
    PDF, 738 Кб, Версия: C, Файл опубликован: 19 дек 2012
  • How to Measure the Control Loop of DCS-Control Devices (Rev. A)
    PDF, 259 Кб, Версия: A, Файл опубликован: 9 авг 2012
  • High-efficiency low-ripple DCS-Control offers seamless PWM/pwr-save transitions
    PDF, 605 Кб, Файл опубликован: 25 июл 2013
  • Understanding frequency variation in the DCS-Control(TM) topology
    PDF, 224 Кб, Файл опубликован: 30 окт 2015
  • Design considerations for a resistive feedback divider in a DC/DC converter
    PDF, 393 Кб, Файл опубликован: 26 апр 2012
  • Five steps to a great PCB layout for a step-down converter
    PDF, 162 Кб, Файл опубликован: 29 янв 2015
  • Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)
    PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
  • Testing tips for applying external power to supply outputs without an input volt
    PDF, 110 Кб, Файл опубликован: 24 окт 2016
  • Basic Calculation of a Buck Converter's Power Stage (Rev. B)
    PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
  • QFN and SON PCB Attachment (Rev. B)
    PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
  • Powering the MSP430 from a High Voltage Input using the TPS62122 (Rev. C)
    PDF, 330 Кб, Версия: C, Файл опубликован: 12 янв 2012
Серия: TPS62140 (2)
На английском языке: Datasheet Texas Instruments TPS62140RGTT
