Datasheet Texas Instruments MSP430FR2310IRGYT — Даташит
СерияMSP430FR2310
МодельMSP430FR2310IRGYT
Микроконтроллер со сверхнизким энергопотреблением, тактовая частота 16 МГц, 2 КБ FRAM, 1 КБ SRAM, 12 входов/выходов, 8-канальный АЦП10, операционные усилители, TIA 16-VQFN от -40 до 85
MSP430FR231x Mixed-Signal Microcontrollers datasheet
PDF, 1.7 Мб, Версия: C, Файл опубликован: 11 сен 2017
Pin16
Package TypeRGY
Industry STD TermVQFN
JEDEC CodeR-PQFP-N
Package QTY250
CarrierSMALL T&R
МаркировкаFR2310
Width (мм)3.5
Length (мм)4
Thickness (мм).9
Pitch (мм).5
Max Height (мм)1
ADCADC10 - 8ch
AESN/A
Active Power126 uA/MHz
Additional FeaturesOpAmp,Transimpedance amplifier,Real-Time Clock,Watchdog,Temp Sensor,Brown Out Reset
BSLUART
CPUMSP430
Comparators2
Featuredfr2
Тактовая частота16 МГц
GPIO Pins16
I2C1
Max VCC3.6
Min VCC1.8
MultiplierN/A
Non-volatile Memory2 KB
Package GroupVQFN
Package Size: mm2:W x L16VQFN: 14 mm2: 3.5 x 4(VQFN) PKG
RAM1 KB
SPI2
Security EnablerCryptographic acceleration,Debug security,Physical security,Secure FW and SW update,Software IP protection
Special I/ON/A
Standby Power1 LPM3-uA
Timers - 16-bit2
UART1
Wakeup Time10 us
  • Evaluation Modules & Boards: MSP-FET430U20
    MSP-FET + MSP-TS430PW20 FRAM Microcontroller Development Kit Bundle (Microcontrollers not Included)
  • Evaluation Modules & Boards: MSP-TS430PW20
    Target Development Board for MSP430FR2000, MSP430FR21x and MSP430FR23x MCUs - 20-pin
  • Evaluation Modules & Boards: MSP-EXP430FR2311
    MSP430FR2311 LaunchPad Development Kit
  • How to Use the Integrated Operational Amplifiers on MSP430FR2311
    PDF, 190 Кб, Файл опубликован: 19 июл 2016
    In sensing applications, operational amplifiers are often needed to condition (for example, to amplify and filter) the analog sensor output so that it can be properly sampled by the analog-to-digital converter on the MCU. This application report provides a guide to set up the integrated operational amplifiers (TIA and SAC_OA) on the MSP430FR2311 microcontroller. Examples are provided for using the
  • VLO Calibration on the MSP430FR4xx and MSP430FR2xx Family (Rev. A)
    PDF, 78 Кб, Версия: A, Файл опубликован: 19 фев 2016
    MSP430FR4xx and MSP430FR2xx (FR4xx/FR2xx) family microcontrollers (MCUs) provide various clock sources, including some high-speed high-accuracy clocks and some low-power low-system-cost clocks. Users can select the best balance of performance, power consumption, and system cost. The on-chip very low-frequency oscillator (VLO) is a clock source with 10-kHz typical frequency included in FR4xx/FR2xx
  • Migrating From MSP430 F2xx and G2xx Families to MSP430 FR4xx and FR2xx Family (Rev. E)
    PDF, 237 Кб, Версия: E, Файл опубликован: 4 май 2018
    This application report helps to ease the migration from MSP430F2xx flash-based MCUs to the MSP430FR4xx and MSP430FR2xx family of FRAM-based MCUs. It discusses programming system hardware core architecture and peripheral considerations. The intent is to highlight key differences between the two families. For more information on the use of the MSP430FR4xx and MSP430FR2xx devices see the MSP430
  • Semiconductors > Microcontrollers (MCU) > MSP430 ultra-low-power MCUs > MSP430FRxx FRAM
На английском языке: Datasheet Texas Instruments MSP430FR2310IRGYT
