Datasheet Texas Instruments THS1030CDWR — Даташит
СерияTHS1030
МодельTHS1030CDWR
10-разрядный АЦП, 30 MSPS, одноканальный, комп.
3-V to 5.5-V 10-Bit, 30 MSPS CMOS Analog-to-Digital Converter datasheet
PDF, 1.0 Мб, Версия: E, Файл опубликован: 30 окт 2003
IC ADC 10BIT PIPELINED 28SOIC. 10 Bit Analog to Digital Converter 1 Input 1 Pipelined 28-SOIC. Data Acquisition - Analog to...
THS1030CDWR
355 ₽
THS1030CDWR
388 ₽
THS1030CDWR
406 ₽
THS1030CDWR
с TLC876, индикатор выхода за пределы диапазона, PowerDown 28-SOIC от 0 до 70
Pin28
Package TypeDW
МаркировкаTH1030
Width (мм)7.5
Length (мм)17.9
Thickness (мм)2.35
Max Height (мм)2.65
Рекомендуемая замена
ReplacementADS825E
Replacement CodeP
# Input Channels1
Analog Input BW(MHz)150
Approx. Price (US$)6.94 | 100u
АрхитектураPipeline
DNL(Max)(+/-LSB)1
ENOB(Bits)7.8
INL(Max)(+/-LSB)2
Input BufferNo
Input Range2V (p-p)
InterfaceParallel CMOS
Operating Temperature Range(C)-40 to 85
0 to 70
Package GroupTSSOP
Package Size: mm2:W x L (PKG)28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP)
Power Consumption(Typ)(mW)150
Reference ModeExt
Int
Resolution(Bits)10
SFDR(dB)53
SINAD(dB)48.6
SNR(dB)49.4
Sample Rate(Max)(MSPS)30
RoHSНе совместим
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200EVM: Low Cost Portable Power Supply
  • CDCE62005 as Clock Solution for High-Speed ADCs
    PDF, 805 Кб, Файл опубликован: 4 сен 2008
    TI has introduced a family of devices well-suited to meet the demands for high-speed ADC devices such as the ADS5527 which is capable of sampling up to 210 MSPS. To realize the full potential of these high-performance products it is imperative to provide a low phase noise clock source. The CDCE62005 clock synthesizer chip offers a real-world clocking solution to meet these stringent requirements
  • Smart Selection of ADC/DAC Enables Better Design of Software-Defined Radio
    PDF, 376 Кб, Файл опубликован: 28 апр 2009
    This application report explains different aspects of selecting analog-to-digital and digital-to-analog data converters for Software-Defined Radio (SDR) applications. It also explains how ADS61xx ADCs and the DAC5688 from Texas Instruments fit properly for SDR designs.
  • Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)
    PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
    This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers
  • Semiconductors > Data Converters > Analog to Digital Converter > High Speed ADC (>10MSPS)
На английском языке: Datasheet Texas Instruments THS1030CDWR
