Datasheet Texas Instruments SN74AS00NSR — Даташит
СерияSN74AS00
МодельSN74AS00NSR
Четверные логические элементы положительного И-НЕ с 2 входами 14-SO от 0 до 70
Quadruple 2-Input Positive-NAND Gates datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 1 дек 1994
Pin14
Package TypeNS
Industry STD TermSOP
Package QTY2000
Маркировка74AS00
Width (мм)5.3
Length (мм)10.3
Thickness (мм)1.95
Max Height (мм)2
Bits4
F @ Nom Voltage(Max)35 Mhz
ICC @ Nom Voltage(Max)0.003 мА
Output Drive (IOL/IOH)(Max)0.4/-8 мА
Package GroupSO
Package Size: mm2:W x L14SO: 80 mm2: 7.8 x 10.2(SO) PKG
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
Voltage(Nom)5 В
tpd @ Nom Voltage(Max)4.5 нс
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Semiconductors > Logic > Gate > NAND Gate
На английском языке: Datasheet Texas Instruments SN74AS00NSR
