Datasheet Texas Instruments TLV1117CKTER — Даташит
СерияTLV1117
МодельTLV1117CKTER
TLV1117 Adjustable and Fixed Low-Dropout Voltage Regulator datasheet
PDF, 1.7 Мб, Версия: L, Файл опубликован: 26 окт 2014
Pin3
Package TypeKTE
Industry STD TermPFM
JEDEC CodeR-PSFM-G
МаркировкаTLV1117C
Width (мм)8
Length (мм)9.4
Thickness (мм)1.91
Pitch (мм)2.54
Max Height (мм)2.03
Accuracy(%)1
Additional FeaturesOvercurrent Protection
Thermal Shutdown
Approx. Price (US$)0.18 | 1ku
Iout(Max)(A)0.8
Iq(Typ)(mA)1.7
Noise(uVrms)411
Operating Temperature Range(C)-40 to 125
0 to 125
Output OptionsAdjustable Output
PSRR @ 100KHz(dB)28
Package GroupDDPAK/TO-263
SON
SOT-223
TO-220
TO-252
Package Size: mm2:W x L (PKG)See datasheet (TO-220)
See datasheet (PFM)
See datasheet (SON)
Powered LoadFPGA
Microcontroller
Microprocessor
Regulated Outputs(#)1
Vdo(Typ)(mV)1200
Vin(Max)(V)15
Vin(Min)(V)2.7
Vout(Max)(V)13.7
Vout(Min)(V)1.25
RoHSНе совместим
  • Evaluation Modules & Boards: TPA3245EVM
    TPA3245 100W Stereo/ 200W Mono PurePathв„ў Ultra-HD Analog Input Power Stage Evaluation Module
  • Evaluation Modules & Boards: TPA3244EVM
    TPA3244 Stereo 40-W Continuous/100-W Peak PurePathв„ў Ultra-HD Analog Input Pad Down Class-D EVM
  • Evaluation Modules & Boards: TPA3255EVM
    TPA3255 325W Stereo/ 600W mono PurePath Ultra-HD Analog Input Power Stage Evaluation Module
  • Evaluation Modules & Boards: LM317A-337N-EVM
    3-Terminal Adjustable Regulators Evaluation Module
  • Designing Low Cost Flyback Power Supply Using Boost Converter (TPS61165) for HF
    PDF, 4.2 Мб, Файл опубликован: 17 апр 2014
    TPS61165, LMR14206, TPS5401, AMC1100, TLV1117I-33, TLV1117I-50 Designing low cost flyback supply using boost converter for HF Inverter
  • How to pick a linear regulator for noise-sensitive applications
    PDF, 255 Кб, Файл опубликован: 22 янв 2013
  • ANY-OUTв„ў LDO Controlled by I2Cв„ў IO Expander Device (Rev. A)
    PDF, 1.2 Мб, Версия: A, Файл опубликован: 20 сен 2012
    TPS74201, TPS74301, TPS74401, TPS7A80xx, TPS7A8101 ANY-OUTв„ў LDO Controlled by I2Cв„ў IO Expander Device
  • Hybrid Battery Charger with Load Control for Telecom Equipments
    PDF, 391 Кб, Файл опубликован: 28 окт 2014
  • A 3-A, 1.2-Vout linear regulator with 80% efficiency and Plost < 1W
    PDF, 158 Кб, Файл опубликован: 10 окт 2006
  • Cycloneв„ў III FPGA Starter Kit Power Reference Design
    PDF, 314 Кб, Файл опубликован: 27 мар 2008
    This power supply was designed to power the 3C25F324 starter kit. This reference design has many benefits over the existing power supply found on the starter kit demonstration board.
  • Intel EP80579 Tolopai System-on-Chip Reference Design
    PDF, 66 Кб, Файл опубликован: 21 июл 2010
  • Techniques for accurate PSRR measurements
    PDF, 1.9 Мб, Файл опубликован: 28 окт 2013
  • A Topical Index of TI Supply Voltage Supervisor (SVS) Application Notes
    PDF, 56 Кб, Файл опубликован: 15 июн 2015
  • Selecting the correct IC for power-supply applications
    PDF, 184 Кб, Файл опубликован: 14 дек 2006
  • AN-1950 Silently Powering Low Noise Applications (Rev. A)
    PDF, 10.5 Мб, Версия: A, Файл опубликован: 22 апр 2013
    This application report explains how to implement a low noise switch mode power supply solution. Itintroduces the sources of noise and explain how to minimize them. A big factor in noise generation andpropagation is the printed circuit board layout. Important basics are discussed. Circuit measurementtechniques are also explained to guide a design engineer towards a low noise but efficient so
  • LDO Performance Near Dropout
    PDF, 149 Кб, Файл опубликован: 8 окт 2010
  • AN-1482 LDO Regulator Stability Using Ceramic Output Capacitors (Rev. A)
    PDF, 169 Кб, Версия: A, Файл опубликован: 25 апр 2013
    Ultra-low ESR capacitors such as ceramics are highly desirable because they can support fast-changingload transients and also bypass very high frequency noise coming from switching converter powersources which a linear regulator can not reject. However using ultra-low ESR capacitors on the output ofan LDO regulator requires that specific design changes be implemented to ensure loop stabili
  • Linear and Switching Voltage Regulator Fundamental Part 1
    PDF, 183 Кб, Файл опубликован: 21 мар 2007
  • AN-1028 Maximum Power Enhancement Techniques for Power Packages (Rev. B)
    PDF, 684 Кб, Версия: B, Файл опубликован: 6 май 2013
    The purpose of this application report is to aid the user in maximizing the power handling capability of Texas Instruments power packages by using the SOT-223 as an example.
  • Fundamental Theory of PMOS LDO Voltage Regulators
    PDF, 66 Кб, Файл опубликован: 7 май 1999
    This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements.
  • Using Thermal Calculation Tools for Analog Components
    PDF, 1.1 Мб, Файл опубликован: 2 сен 2010
    This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
На английском языке: Datasheet Texas Instruments TLV1117CKTER
