Datasheet Texas Instruments UCC3889DTR — Даташит
| Серия | UCC3889 |
| Модель | UCC3889DTR |
Контроллер автономного источника питания 8-SOIC от 0 до 70
Off-line Power Supply Controller datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 20 фев 2003
Купить UCC3889DTR на РадиоЛоцман.Цены — от 29 до 315 ₽39 предложений от 18 поставщиков Интегральные микросхемы Микросхемы управления электропитанием - AC/DC преобразователи | |||
| UCC3889DTR Texas Instruments | 76 ₽ | ||
| UCC3889DTR Texas Instruments | 268 ₽ | ||
| UCC3889DTR Texas Instruments | от 312 ₽ | ||
| UCC3889DTR Texas Instruments | по запросу | ||
| Pin | 8 |
| Package Type | D |
| Industry STD Term | SOIC |
| JEDEC Code | R-PDSO-G |
| Package QTY | 2500 |
| Carrier | LARGE T&R |
| Маркировка | UCC3889 |
| Width (мм) | 3.91 |
| Length (мм) | 4.9 |
| Thickness (мм) | 1.58 |
| Pitch (мм) | 1.27 |
| Max Height (мм) | 1.75 |
| Mechanical Data | Скачать |
| Control Method | Feedforward,Voltage |
| Duty Cycle(Max) | 55 % |
| Frequency(Max) | 250 kHz |
| Gate Drive(Typ) | 0.2 A |
| Рабочий диапазон температур | от 0 до 70 C |
| Package Group | SOIC |
| Rating | Catalog |
| Special Features | Error Amplifier,Soft Start |
| Topology | Flyback |
| UVLO Thresholds On/Off | 8.4/6.3 В |
| Vin(Max) | 9.3 В |
| Vin(Min) | 8.4 В |
- Evaluation Modules & Boards: UCC3889EVM
UCC3889 Evaluation Module
- DN-59A UCC3889 Bias Supply Controller EVM Kit - SchematicPDF, 144 Кб, Файл опубликован: 5 сен 1999
This design note presents a schematic and a photograph of the top-side layout for the UCC3889 Off-Line Bias Supply Controller IC Evaluation Kit. This board accepts both conventional "through-hole" or leaded components as well as their surface-mount counterparts. An additional prototyping area allows engineers to further customize these units to address their projects' specific needs. Component lis - U-149 Elegantly Simple Off-Line Bias Supply for Very Low Power ApplicationsPDF, 328 Кб, Файл опубликован: 5 сен 1999
The UCC3889 controller is an off-line, low-power, low-voltage, regulated-bias power supply. The unique circuit topology in this device can be visualized as two cascaded flyback converters, each operating in the discontinuous mode, and both driven from a single external power switch. The significant benefit of this approach is voltage conversion ratios of 400V to 12V, with no transformer and low in
Серия: UCC3889 (5)
- UCC3889D UCC3889DG4 UCC3889DTR UCC3889N UCC3889NG4
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > PWM and Resonant Controller
