Datasheet Texas Instruments TL750M08CKCE3 — Даташит
СерияTL750M08
МодельTL750M08CKCE3
LDO с одним выходом, 750 мА, фиксированный (8,0 В), низкий ток покоя, защита от сброса нагрузки 60 В 3-TO-220 0–125
TL750M Series Low-Dropout Voltage Regulator (Rev. N)
PDF, 1.2 Мб, Версия: N, Файл опубликован: 1 янв 2019
IC REG LINEAR 8V 750MA TO220-3. Linear Voltage Regulator IC 1 Output 750mA TO-220-3. PMIC - Voltage Regulators - Linear
Hi-Tech Circuit Group
TL750M08CKCE3
TL750M08CKCE3
TL750M08CKCE3
TL750M08CKCE3
Pin3
Package TypeKC
Industry STD TermTO-220
JEDEC CodeR-PSFM-T
МаркировкаTL750M08C
Width (мм)9.02
Length (мм)10.17
Thickness (мм)4.58
Pitch (мм)2.54
Max Height (мм)4.7
Accuracy(%)1
Additional FeaturesOvercurrent Protection
Thermal Shutdown
Approx. Price (US$)0.42 | 1ku
Fixed Output Options(V)8
Iout(Max)(A)0.75
Iq(Typ)(mA)5
Noise(uVrms)500
Operating Temperature Range(C)0 to 125
Output OptionsFixed Output
Package GroupTO-220
Package Size: mm2:W x L (PKG)See datasheet (TO-220)
Powered LoadFPGA
Microcontroller
Microprocessor
Regulated Outputs(#)1
Vdo(Typ)(mV)600
Vin(Max)(V)26
Vin(Min)(V)9
Vout(Max)(V)8
Vout(Min)(V)8
RoHSНе совместим
  • Using Thermal Calculation Tools for Analog Components
    PDF, 1.1 Мб, Файл опубликован: 2 сен 2010
    This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o
Серия: TL750M08 (2)
На английском языке: Datasheet Texas Instruments TL750M08CKCE3
