Datasheet Texas Instruments LM2676T-3.3/NOPB — Даташит
СерияLM2676
МодельLM2676T-3.3/NOPB
SIMPLE SWITCHER® 8–40 В, 3 А, понижающий стабилизатор с малым количеством компонентов 7-TO-220 от -40 до 125
LM2676 SIMPLE SWITCHERВ® High Efficiency 3-A Step-Down Voltage Regulator datasheet
PDF, 2.1 Мб, Версия: K, Файл опубликован: 30 июн 2016
Pin77
Package TypeNDZNDZ
Industry STD TermTO-220TO-220
JEDEC CodeR-MSFM-LR-MSFM-L
Package QTY4545
CarrierTUBETUBE
МаркировкаLM2676T-3.3
Width (мм)10.1610.16
Length (мм)14.98614.986
Thickness (мм)4.5724.572
Pitch (мм)1.271.27
Max Height (мм)4.74.7
Control ModeVoltage Mode
Duty Cycle(Max)91 %
Iout(Max)3 A
Iq(Typ)4.2 мА
Package GroupTO-220
Regulated Outputs1
Special FeaturesEnable
Switching Frequency(Max)260 kHz
Switching Frequency(Min)260 kHz
ТипConverter
Vin(Max)40 В
Vin(Min)8 В
Vout(Max)37 В
Vout(Min)1.23 В
  • Evaluation Modules & Boards: LM2676S-ADJEVM
    LM2676 Step-Down Converter Evaluation Module
  • AN-1187 Leadless Leadframe Package (LLP) (Rev. R)
    PDF, 21.3 Мб, Версия: R, Файл опубликован: 7 май 2013
    This application report discusses the Leadless Leadframe Package (LLP).
  • AN-1Positive-to-Negative Buck-Boost Converter Using LM267x SIMPLE SWITCHER (Rev. E)
    PDF, 291 Кб, Версия: E, Файл опубликован: 23 апр 2013
    The third generation Simple Switcher LM267X series of regulators are monolithic integrated circuits withan internal MOSFET switch. These regulators are simple to use and require only a few externalcomponents. In this article the design of a polarity inverting converter will be discussed.
  • Low EMI Layout Made SIMPLE With LM43600/1/2/3 and LM46000/1/2 (Rev. A)
    PDF, 512 Кб, Версия: A, Файл опубликован: 12 сен 2014
    Printed Circuit Board (PCB) layout for Switched Mode Power Supplies (SMPS) is critical to achieve proper converter operation good thermal performance and excellent radiated EMI performance. Optimized board layout for low radiated EMI is made very simple by the package and pin arrangement of the SIMPLE SWITCHER Synchronous Buck Converter family LM4360x and LM4600x
  • Simple Techniques Minimize Cross-Coupling in Distributed Power Systems
    PDF, 335 Кб, Файл опубликован: 21 мар 2007
LM2676T3.3/NOPB, LM2676T 3.3/NOPB
На английском языке: Datasheet Texas Instruments LM2676T-3.3/NOPB
