Datasheet ТI TPS61070DDCRG4 — Даташит
СерияTPS61070
МодельTPS61070DDCRG4
Datasheet Texas Instruments TPS61070DDCRG4
Регулируемый переключатель на 600 мА, повышающий преобразователь ЧИМ/ШИМ с эффективностью 90 % в ThinSOT-23 6-SOT-23-THIN от -40 до 85
TPS6107x 90% Efficient Synchronous Boost Converter With 600-mA Switch datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 25 мар 2015
  • Single-cell Battery Discharge Characteristics Using the TPS61070 Boost Converter
    PDF, 772 Кб, Файл опубликован: 24 авг 2004
    This application report presents practical single-cell battery discharge characteristics in real-world application, and primarily focuses on the varying internal impedance of a battery and how that affects the battery terminal voltage.
  • Reducing Output Ripple Voltage of TPS61070
    PDF, 2.0 Мб, Файл опубликован: 7 июн 2005
    This application report presents a possible solution to reduce the output ripple voltage of the TPS61070 during PFM-mode operation and primarily focuses on modifying the feedback loop response and how that affects the output ripple voltage of Bluetooth(TM) headset application with a single-cell alkaline battery.
  • TPS61020 Boost Converter Start-Up and Precharge
    PDF, 488 Кб, Файл опубликован: 28 янв 2010
    The TPS61020 is a highly integrated, low-power, boost converter ideally suited for portable battery-powered equipment. To improve start-up performance from a power-limited source such as a battery, the TPS6102x family uses different steps and modes to reduce demand on the battery. This prevents the battery bus from sagging during start-up and improves start-up operation at low voltage.
  • How to Choose the Appropriate TPS6107x for your Application
    PDF, 87 Кб, Файл опубликован: 27 фев 2007
  • 2Q 2012 Issue Analog Applications Journal
    PDF, 2.4 Мб, Файл опубликован: 26 апр 2012
  • Accurately measuring efficiency of ultralow-IQ devices
    PDF, 254 Кб, Файл опубликован: 22 янв 2014
  • Five Steps to a Good PCB Layout of the Boost Converter
    PDF, 701 Кб, Файл опубликован: 3 май 2016
  • Minimizing Ringing at the Switch Node of a Boost Converter
    PDF, 201 Кб, Файл опубликован: 15 сен 2006
    The application report explains how to use proper board layout and/or a snubber to reduce high-frequency ringing at the switch node of a boost converter.
  • Design considerations for a resistive feedback divider in a DC/DC converter
    PDF, 393 Кб, Файл опубликован: 26 апр 2012
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: TPS61070 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TPS61070DDCRG4
Политика конфиденциальности
